Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 05-05-2012, 09:59 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Paragon NTFS for mac or HFS for windows - do I need it when using a shared folder?
I recently set up a shared 1TB usb external drive, that is connected to my mac(OSX 10.6.8), and formatted as Mac OS Extended(journaled).
My PC running windows 7 x64 sees it fine, and doesn't seem to have a problem reading or writing files to it.
Do I really need one of the Paragon products to share files between the two OS's? Am I going to end up with data corruption if I don't use it? I'm a little confused as to why this seems to work fine so far without adding any of this paragon type software.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 05-12-2012, 06:46 PM
Default Re: Paragon NTFS for mac or HFS for windows - do I need it when using a shared folder
Really? No one else had tried this?
Well, for a week it has worked perfectly for me, I have moved at least 100GB of files between the two machines without issue. I think the only time you'd need the paragon software would be if connecting an external usb or fw drive of the HFS format directly to the PC. Connecting it to the mac and sharing over the network appears to work differently. It's so easy to set up, I know that as long as I have both a mac and a PC I will never need any of the paragon software.
- John
Old 05-25-2012, 07:12 AM
manik manik is offline
Though my case is not exactly the same, the condition may be similar...
I am using a PC with dual boot of OSX 10.7.3 (Hackintosh) and Win7 x64. The HDD drivers are:
SATA 500GB 7200rpm HFS+ for OSX system, installs PT10.2 Mac
SATA 500GB 7200rpm NTFS for Win system, installs PT10.2 Win
SATA 1TB 7200rpm HFS+ for common data storage
SATA 128GB(SSD) NTFS for large sound samples
then I installed Paragon "NTFS for Mac" and and "HFS+ for Win" on each side. Both PT versions are working very fine, placing my projects to 1TB HFS+ disk. Everything works fine and I don't have to think which format type was applied to each partition.
When I try to benchmark of the data HDD from Windows using Crystal Disk Mark, both NTFS and HFS+ partitions could write/read in at around 100MB/s speed. (I did not check the performance of NTFS W/R access from OSX, because I could not fine a good tool to measure it.)
ASUS P8Z68-V/GEN3, Intel Core i7 2600K 3.4GHz, 16GB RAM
OSX86 Lion 10.7.3, Pro Tools 10.2
MBOX2, M-Audio Axiom Pro 49
http://himemanik.com/
http://www.facebook.com/himemanik2
Old 05-26-2012, 06:47 AM
Good to know. For my application, I have a 1TB external that includes audio files that I manipulate with both a pc and a mac, I dont like rebooting, and in the past I tried parallels, but it made my mac system unstable. When using an external that was formatted in FAT, it always seemed to suffer from slow performance on one machine depending on which OS I formatted it with. The shared folder trick seems to work great for me so far, I dont think I'm getting 100MB/s, but the performance is great so far.
- John
Old 05-27-2012, 01:15 AM
Shan's Avatar
Shan Shan is offline
Do you have Pro Tools running on your PC as well? What version? The Pro Tools installer on PC also installs an HFS+ Driver by MediaFour.
Unfortunately though, 10.2 no longer has the HFS+ driver installer, so you'll need to purchase MacDrive or Paragon HFS+ for Windows for that specific release.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 05-27-2012, 05:33 PM
Shane
Interesting, I don't have pro tools on the pc. Haven't tried it, but I don't think an hfs drive will work connected directly to it. it certainly does work with the drive connected to the mac, with file sharing enabled for the drive though. I was always under the assumption that a pc wouldnt be able to write to an hfs drive without special software like paragon, period... But it definitely can over the network.
- John
Old 05-27-2012, 05:46 PM
necjamc necjamc is offline
Default
Except for 10.2 (although you can grab the installer from 10.0) with the version of Mac drive that installs you can read and write to HFS drives on PC without an issue. But not at all without "helper" app. But as stated with pro tools comes with it free
"Can't Create Pro Tools Shared Folder" Crash sonicksound Pro Tools 11 1 08-23-2013 10:22 AM
Shared folder error cmhawke Getting Started 10 05-09-2013 03:51 AM
Pro Tools Shared Folder MichaelKhan Windows 0 10-15-2012 01:37 PM
Anyone using NTFS for mac - software - by Paragon YYR123 macOS 8 04-25-2012 09:34 AM
Can Macs read NTFS Windows partitions? SixChurchStreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-07-2008 06:37 AM
