Old 07-29-2000, 04:34 AM
relaxo relaxo is offline
Default Other Hardware Solutions for Logic Audio?
I am a composer and my primary tool in music is Logic Audio. I was forced into ProTools hardware about three years ago after using an AudioMedia II card and also Emagic's Audiowerk 8 card. They were both disasters with severe latency, noise and automation problems. ProTools hardware worked!
I am very unhappy with the current condition of Logic's TDM. However, ProTools 5 software is virtually unusable as a composition tool. It is really purely a great audio tool. Midi, scoring and ARRANGING features in PT5 rate a one on a scale of one to twenty.
Are there any other hardware solutions that can interface with Logic in a native environment on a G4 without the aforementioned problems that I experienced with non-TDM hardware three years ago? Is ProTools still really the only hardware option without latency issues?
Thanks,
Scott
PS-No I don't want to sync Logic to PT or tranfer final audio tracks from Logic to PT. That's no way to work.
[This message has been edited by relaxo (edited July 29, 2000).]
Old 07-29-2000, 02:26 PM
Grey Grey is offline
Default Re: Other Hardware Solutions for Logic Audio?
hopefully emagic will get Logic together sone....
I use Logic with the 888/24's..
also have Pro tools
together they almost make the perfect solution
grey
Old 07-29-2000, 05:59 PM
Jules Jules is offline
You could always supercharge a MOTU set up with an Apogee converter AN AD8000 to get the quality up.: with a light pipe card or the new Trac2 which has mic pre amps, or a Rosetta, or a PSX100.
Jules
Jules
London, UK
Come hang with us here!
www.gearslutz.com
Old 07-30-2000, 12:23 AM
rope77 rope77 is offline
Did you take a look at MOTU 2408 System? I am in the same situation as you and a few people have said to look into that system. It does support Logic and it is expandable. It says it is 24/96 but i don't know the audio quality. i have not been able to do a/b each system side by side.Hope this helps some.
Rope
Pro Logic solutions Mark Wheaton Post - Surround - Video 6 07-20-2007 06:37 AM
Logic Audio with PT III hardware??? NakedI Pro Tools TDM Systems (Mac) 2 03-05-2001 01:55 PM
Logic Audio with PT III hardware??? NakedI Pro Tools TDM Systems (Mac) 0 03-05-2001 01:21 AM
Audio Logic ... Hardware insert how ? thetan Tips & Tricks 1 09-29-2000 09:31 AM
Digi 001 hardware + Logic Audio thetan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-05-2000 08:54 AM
