Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 01-22-2020, 08:46 PM
SomeOtherGuy SomeOtherGuy is offline
Default Can't get MTRX Dante card to work...
I just installed the 64x64 Dante option card in my MTRX, and hooked it up via ethernet, but can't get any Mac system audio to play. It's showing up in DADman software and it's selected as the audio out in the Mac. It's also routed to the MTRX D/A channels 1 & 2 for output in the Monitor profile. There has to be something I'm missing here...thx.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 01-22-2020, 09:18 PM
creativecontrol's Avatar
Default Re: Can't get MTRX Dante card to work...
Greetings,
Are you using Dante Virtual Soundcard to stream audio from the system into your MTRX? If not, I would highly recommend it.
Make sure you patch the necessary connections from your computer out(machine name) to an input pair on your MTRX Dante IO.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-22-2020, 09:26 PM
Originally Posted by creativecontrol View Post
Greetings,
Yes, forgot to mention, I am using Dante Virtual Soundcard and it is patched correctly as far as I can tell...
Old 01-22-2020, 09:29 PM
Ensure that the streams are active, patches are indicated in green in Dante Control and that your DVS sample rate is matched to the sample rate of your MTRX.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-22-2020, 09:32 PM
Here's what it looks like, if this helps:
File Type: jpg Screen Shot 2020-01-22 at 9.30.55 PM.jpg (55.8 KB, 0 views)
Old 01-22-2020, 09:40 PM
and this:
File Type: png Screen Shot 2020-01-22 at 9.40.09 PM.png (92.6 KB, 0 views)
Old 01-22-2020, 09:44 PM
I presume your "Mac Audio Out" source is part of your main Control Room monitor set which you have assigned to the onboard 64 channel MTRX daughterboard. You don't need to make any patches in the router/matrix section if you are simply attempting to feed the DVS source to your stereo monitor outputs which are assigned to your DA's.
Can you also send me a screengrab of the patch point routing in Dante Controller and also your Monitor Profile assignments in DADman? Thanks.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-22-2020, 09:46 PM
Thanks, here's the MOM:
File Type: jpg Screen Shot 2020-01-22 at 9.45.33 PM.jpg (27.4 KB, 0 views)
Old 01-22-2020, 09:49 PM
I'm also not sure why AES is selected:
File Type: jpg Screen Shot 2020-01-22 at 9.48.22 PM.jpg (49.1 KB, 0 views)
Old 01-22-2020, 09:52 PM
Once again, don't worry about the routing matrix view. You need to focus on the monitor profile and ensure that you have patched the Dante Virtual Soundcard outputs from the Mac operating system into the 1-2 MTRX Inputs on your Dante Card in your unit. Please send me an image showing your patch point in Dante Controller so I can verify. Also, ensure that your Default Sound Output in the System Settings for your Mac is set to Dante Virtual Soundcard.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
MTRX-> HDX or MTRX->Dante ArmyofLight Pro Tools | MTRX & MTRX Studio 34 04-08-2021 04:51 PM
Avid MTRX with Dante SRC Question apasco Pro Tools | MTRX & MTRX Studio 3 01-15-2020 06:24 PM
MTRX hookup question, Dante vs Digilink SomeOtherGuy Pro Tools | MTRX & MTRX Studio 26 01-03-2019 11:29 AM
MTRX Dante latency stuck at 1ms LukeHoward Pro Tools | MTRX & MTRX Studio 1 02-19-2018 11:13 PM
MTRX Sync Dante and Video laki Pro Tools | MTRX & MTRX Studio 10 12-05-2017 02:26 AM
