Old 03-10-2024, 07:41 PM
MarkH MarkH is offline
Default S4 adding additional modules
Hi all,
Can any modules be added above the S4 CSM Channel Strip Module or is that section of the frame considered completely occupied when it has a CSM?
Thanks,
Mark
Old 03-10-2024, 08:39 PM
creativecontrol's Avatar
Default Re: S4 adding additional modules
Those S4 buckets in the frame which contain Channelstrip Modules are complete with CSM + CDM (Display Modules). Especially with the extended, deeper CDM bracket, there is no additional room left in the bucket.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-11-2024, 06:51 AM
Ok great, that's what I suspected. I've got a 4' frame on the way and will add a Joystick module. Looks like I'll be putting it on the end. Thanks!
Adding additional audio inputs to Protools DAW prospectmusic Windows 4 10-26-2016 12:12 PM
Adding an M-box mini as an additional interface. The cat General Discussion 4 11-29-2012 01:23 PM
adding additional simultanious tracks teddyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-05-2009 04:34 PM
Adding additional mic pres? projectjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-12-2007 07:09 AM
adding additional mics to digi002r sethbrand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-24-2005 05:32 PM
