Old 02-15-2024, 05:53 AM
inscapesound inscapesound is offline
Default S4 - Assign inserts
Is it possible to assign inserts from the S4?
I’ve been searching and found nothing.
I did find a post from 17 mentioning that it wasn’t possible - but I assume by now it would have been added.
Thanks!
Old 02-15-2024, 07:27 AM
creativecontrol's Avatar
Default Re: S4 - Assign inserts
Greetings,
It is not possible to select any plug-in to instantiate to an insert from the console. You can however choose a favorite DYN and EQ (PT prefs) which can be automatically instantiated by choosing the appropriate function switch from the ChannelStrip Module.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-15-2024, 08:06 AM
Thanks. This seems like such an odd omission especially since it was possible on an older console like the C24. (and assuming Eucon would be a more developed protocol).
Old 02-16-2024, 08:30 AM
EddieJones's Avatar
My reply to you on Facebook gave the reason For this product the majority of users said it was lower priority than the other things we have been implementing.
Can't assign LCR track to 5.1 bus idris Post - Surround - Video 15 02-19-2017 06:04 AM
OMNI inserts only for mic pre , or used as master buss inserts as well Weird Audio Pro Tools TDM Systems (Mac) 3 11-14-2012 09:27 PM
HDX can't assign voices? tribase macOS 1 03-22-2012 09:19 PM
assign ram littlebear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-09-2001 09:54 AM
"memory low...assign more?" charles gladfelter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-31-2001 05:56 AM
