Old 02-07-2024, 02:59 AM
o-matic o-matic is offline
Default 2nd function on expand knobs
Hey all,
I like the idea that the "Sel" button can open up a new way to access hidden settings. But I am currently unable to integrate this new possibility into my basic workflow.
I use the Fab Filter ProQ3 and get it shown on every track I attention. But I can only edit a new custom map on a plugin I open thru the "Ins" switch on the process section (in blue on my Expand Knob Zone"), not on a "basic" EQ (in purple on my Expand Knob Zone).
Editing a new custom map from the EQ section of the master module (in purple) opens a very short list of parameters, and the expand zone turns off completely...
Am I doing something wrong ?
Old 02-07-2024, 04:33 AM
creativecontrol's Avatar
Default Re: 2nd function on expand knobs
Greetings,
The basic flow is - attention a track containing the function you want to create or edit a custom map for, choose the specific function in the Function Scroller such as EQ, DYN, Inserts (more on this), Pan. EQ and DYN are the basic representative dedicated parameter set, which by definition is limited. So, for more advanced parameter mapping, whether EQ or DYN, you should always Touch Inserts on the Function Scroller, then find the specific plug-in Insert and push to expose the parameters on the touchscreen, then choose Custom from the bottom left to start the creation or editing process.
Checkout Switched Parameters - page 137 from the following doc:
https://www.dropbox.com/scl/fi/6krvd...yfv404czj&dl=0
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Dock 2x4 knobs push function? Protone Avid S1, S3, Dock and Control App 5 12-14-2023 08:03 PM
Expand Knobs and Layouts o-matic Avid S4/S6 3 09-26-2022 07:19 AM
Fader Expand Zone Function LDS Avid S4/S6 1 09-01-2020 05:08 AM
Clip Gain loss on Filed Recorded Match Criteria Expand function jon.martins Pro Tools 12 6 11-15-2017 07:32 AM
S6 Expand knobs tanjerinepost2 Avid S4/S6 5 09-17-2015 03:01 PM
