Old 03-14-2016, 09:02 AM
Marsdy Marsdy is offline
Default Softkey shift modifier possible bug?
As I posted in another thread, I've done my own Appset of softkeys.
I'm having a ball with it but I've run into a problem.
I've used quite a few softkey modifiers using the shift key on the Fader Modules to bring up a second function on a softkey. Some of these, for example Clear in the Clip List or Duplicate Track bring up a dialog box in Pro Tools as you'd expect.
However, when a dialog box opens it appears the shift key jams in on or pressed status. So.... when I next hit play I'm effectively hitting shift+play and getting half speed playback. I then need to hit the shift button again to get normal speed playback. It only seems to be the case when I hit a softkey that brings up a dialog box in PT. The shift key modifier works fine otherwise.
I've fiddled with the active/inactive status of the softkey but it hasn't made any difference. It's happening with softkeys with EUCON commands or Key commands assigned to them.
Bug or user error? I can't for the life of me see what I've done wrong?
Dave Marsden
UK
Old 03-14-2016, 12:50 PM
creativecontrol's Avatar
Default Re: Softkey shift modifier possible bug?
I was able to reproduce the behavior you were describing only on a SHIFTed function. We will investigate the issue further.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-14-2016, 01:04 PM
Jeff
Thanks Jeff
Yes it's only on SHIFTed functions here too. SHIFT is getting stuck and causing half speed playback. I guess I could change the modifier key to something else like CONTROL but it means rebooting my muscle memory and the SHIFT key is the most easily accessible.
That said, it's only a minor nuisance. If you hit SHIFT again before playback it gets "unblocked".
Dave Marsden
UK
Old 03-14-2016, 05:39 PM
EddieJones's Avatar
I've added this as a bug. Cheers
Old 03-15-2016, 01:51 AM
Thanks Eddie.
Dave Marsden
UK
SOFTKEY BUG - AFTER 2.0.1 (or malfunction coming?) rcutz Avid S4/S6 14 10-28-2015 09:54 AM
SoftKey Trim to VCAs nickbarkman Artist Series 3 09-03-2015 02:05 PM
Softkey assigned to Option or Shift key Krzysztof Artist Series 9 04-26-2014 07:05 PM
How do I make a Softkey play a mem loc.? Peterjk Artist Series 2 01-12-2013 03:43 AM
Modes softkey SBP ICON & C|24 0 08-12-2009 12:31 PM
