Old 03-04-2021, 02:31 PM
Matt Stephanson Matt Stephanson is offline
Default Re: New Mac Pro Doesn't See Avid Omni HD Native Thunderbolt
@DarrylRamm I’ve done that, yes, and I’ve done that step repeatedly.
You said: “ rerun the installer and in System Preferences>Security & Privacy>General look for the message
I’ve looked for a message, but none have appeared.
I wish the installer could be written such that it intervenes during the install, and after a YES submission, writes into the plist that we’ve allowed the driver to perform whatever system function it needs, and with the appropriate permissions.
But that’s for another day!
At this point, I have an Avid case open, so thanks for your trying to help; I’ll post back what engineering comes up with when it’s all resolved.
Old 03-04-2021, 03:26 PM
DetroitT's Avatar
DetroitT DetroitT is offline
If no message just try Unlock after install. I had this seemingly work, where no message was in Security & Privacy settings.
Are you a granted admin of your Mac? (...IT department)
Old 03-04-2021, 05:38 PM
Thanks, DetroitT.
Yes I’ve got admin privs and can execute sudo commands.
When you Unlocked after install, do you recall the name of the item you unlocked in Privacy?
Cheers,
Old 03-04-2021, 07:29 PM
That gives me some ammo, Darryl - thanks!
I’ll give that a shot (away until Monday) when I’m back.
Cheers and have a good weekend,
Old 03-09-2021, 12:56 PM
Update:
Success!
After running this command, it is all working now.
sudo kextload /Library/Extensions/DigiDal.kext
So if you're in a managed environment like a school, you'll need to run it this way. And you'll need to be the root user to do that (may need your IT dept to run it for you).
Thanks for everyone's support on here, and thanks to Avid!
Mix on . . .
  #16
Old 03-10-2021, 11:01 AM
creativecontrol's Avatar
Great to hear!
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #17
Old 03-20-2021, 09:26 AM
BerndVP BerndVP is offline
Originally Posted by Matt Stephanson View Post
Update:
Success!
Mix on . . .
Do you need to run this command every time if you reboot you're system ?
  #18
Old 03-20-2021, 02:49 PM
No, that should not be necessary.
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #19
Old 03-23-2021, 12:24 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Thanks for helping out, folks!
1. Is there a known issue with an Apple TB3(usb-c) to TB2 adaptor?
We had a problem with one on an iMac Pro going into the cage housing the HD card. All of a sudden PT couldn't see the card. We reinstalled drivers and everything. I eventually swapped TB3 to TB2 adapters between ports and it came back. VERY ODD.
We have spare adapters on hand just in case. For the price, it may be worth keeping a backup around.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
fs Thunderbolt HD native + Omni, PRE agradl Buy & Sell 2 05-06-2020 06:10 AM
Avid HD Omni & HD Native Thunderbolt edwinstar Buy & Sell 3 10-30-2017 05:28 PM
SELLING AVID C|24 omni thunderbolt hd native greenplanet3d Pro Tools HDX & HD Native Systems (Mac) 0 03-24-2016 10:35 AM
Audio Midi Setup doesn't recognize io on Avid HD Omni Thunderbolt MJarzabek Pro Tools HDX & HD Native Systems (Mac) 5 10-10-2013 07:36 AM
Avid HD Native Thunderbolt and OMNI for Sale drogan88 Buy & Sell 0 03-15-2013 06:47 AM
