Old 04-19-2017, 11:19 AM
Philharmonic7 Philharmonic7 is offline
Default Insertion follows playback
Hi everyone,
Could anyone of you fine folks tell me where the "insertion follow playback" button/selection on the S6 is please? Thanks!
Old 04-19-2017, 11:35 AM
creativecontrol's Avatar
Default Re: Insertion follows playback
I don't believe insertion follows playback is:
(A) On a factory soft key
(B) Added to EUCON
You could add a user QWERTY function "n" if you want - or just hit the N key.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 04-19-2017, 11:57 AM
Thanks for getting back to me Jeff.
I do know about the "N" key; however, the way the S6 is setup here won't work. There is no computer monitor, nor keyboard and mouse in front of the S6. It is located left at the very end of the surface, which is not ideal for me to slide my chair back and forth to hit the N key.
It would be a nice to add that in the request list though.
Old 04-19-2017, 06:24 PM
I would recommend simply creating a soft key (on the user pages or anywhere else) and make it a QWERTY function whose value is "n". This is a quick and easy solution.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 04-20-2017, 12:46 AM
Thanks Jeff!
Your input and help has truly been outstanding. I've been mixing at two facilities that have S6 with different configurations. Each has its ups and downs but requires me to adapt in different environments. As I start to dig deeper in the surface, hopefully I won't drive you nuts with a bunch of questions
Insertion Follows Playback 29.97 df bug Nathan W. Post - Surround - Video 2 10-16-2014 10:22 AM
Insertion follows playback weirdness tdowning 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-16-2006 06:10 PM
Insertion follows playback. Seeee Pro Tools TDM Systems (Mac) 2 03-13-2006 04:41 PM
insertion follows playback KingTor ProControl, Control|24, Command|8 5 05-22-2001 04:23 PM
