Old 12-04-2017, 07:14 PM
jmattchan jmattchan is offline
Default Cycle thru EQs in Expanded Knob Mode
Is there a way to cycle through EQs in expanded knob mode (ie. we have an EQ expanded to knob zone 1 and dynamics expanded to knob zone 2. we want to cycle to the next EQ on the strip in knob zone 1).
Thanks,
Matt
Old 12-05-2017, 05:26 AM
creativecontrol's Avatar
Default Re: Cycle thru EQs in Expanded Knob Mode
Yes, agreed completely. Not currently available.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-07-2017, 01:31 PM
stefanboman stefanboman is offline
Yes that would be very much useful!
Fingers crossed for 3.8
Also is there any way to get the current plugin window opened in PT that is on the expanded knob module?
Old 12-09-2017, 04:49 AM
bucha bucha is offline
And a Plug In Window button on the expanded Knob …
Please guys !
Old 12-11-2017, 10:19 AM
innenhofstudios innenhofstudios is offline
u mean this ?
Settings > User > Workstation > General > Check on "Open Plug-ins on Workstation when Editing"
www.innenhofstudios.at
Old 12-11-2017, 04:35 PM
EddieJones's Avatar
and if you are talking about the Attention Expand see the settings on the home page to select which one gets opened.
Old 12-13-2017, 01:57 PM
Thanks Eddie!!
Exactly what I was looking for :) Missed that setting.
Is there a way to close the plug window too on the soft keys?
Also could the attention expand option be turned on/off as a programmed soft key?
Old 12-13-2017, 07:19 PM
EddieJones's Avatar
Yes, both those are available as Softkeys. They are in the PT default softkey layout (somewhere), I'm not in front of an S6 at the moment but let me know if you can't find them.
Old 12-14-2017, 05:34 AM
Greetings,
Just for clarity sake - here's the preference I think we are all referring to and the variation of what you can choose to open:
https://www.dropbox.com/s/vbe0hpjrj5...Knobs.png?dl=0
stefanboman: There are local Soft Key functions on the Extras page to enable and disable on the fly the Attention Expand Knob and Attention Expand Fader Zones:
https://www.dropbox.com/s/vxpqf1z020...t_exp.png?dl=0
All of these topics are discussed in the S6 Operation document 3.7 - which is where I grabbed these images from.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-17-2018, 10:49 AM
hixonjames hixonjames is offline
While rummaging around, trying to figure out how to cycle eq/dyn myself, I did find a (sort of) workaround with this.
Cycling the plugins on the channel strip itself (e.g. double-tap 'Dyn' or 'EQ') will also cycle them in the expand knob zones as well. The only problem with this is the strip you attentioned isn't alway on the same strip. Using 'Always auto-bank to selected track' will always bring it up on the same strip (depending on justification mode), but this doesn't work in layout mode, which is a deal breaker for me.
On a related note, it would be nice if there was an option to enable expand knob zones when attentioning a track. And then, disable expand knob zones when un-attentioning the track.
James Hixon
Pro Tools | HDX 2019.5
S6 M40 19.5
Mac Pro (Late 2013) - Mojave 10.14.5
3 GHz 8-Core Intel Xeon E5
64 GB RAM
HDX end-of-cycle? basehead617 Pro Tools HDX & HD Native Systems (Mac) 49 04-03-2020 10:56 AM
Knob Module Parameter in Layout Mode Bill_Meadows Avid S4/S6 12 08-30-2017 07:58 PM
MBOX 3 PRO in Stand Alone Mode: Volume Knob gives ticks editorbelga FireWire & USB Audio Interfaces (Win) 2 07-21-2013 10:59 PM
Grid mode, shuffle mode, spot mode and slip mode. RogTaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-24-2010 10:30 AM
60 cycle hum indieo General Discussion 3 10-04-2000 09:15 AM
