Old 05-10-2019, 03:36 PM
rcutz rcutz is offline
Default 19.5 activation error
Hi Guys, after installing the new OS ti required a new activation.
I did the offline process and the OS did not recognize the .bin file as being an S6 one.
I need help.
Thanks
Ricardo Cutz
Re-recording mixer/sound editor supervisor.
Http://106db.com.br
Old 05-11-2019, 10:01 AM
EddieJones's Avatar
Default Re: 19.5 activation error
I think you are now sorted by Customer Service right?
Old 05-11-2019, 10:45 AM
RedRock RedRock is offline
I can't help but I have the same problem.
Old 05-12-2019, 06:08 AM
Jeff Komar made a kind of "hot line" with me and a find a solution issuing a NFR so I could keep working without interruption, but I believe a definitive fix is in research, so it did not happen again.
Must say Jeff was fast as hell and really helpful!! Many Thanks for him!
best
Ricardo
Ricardo Cutz
Http://106db.com.br
Old 05-16-2019, 01:06 AM
[email protected] mjr@du.se is offline
I'm seeing the same issue on our S6 M10 after updating to 2019.5 - need to reactivate but the license file isn't recognized as a valid license for M10 even though we have a support contract in place.
Tried calling support but got disconnected straight away but have opened up a support case on the support portal.
Any workaround in the meantime would be greatly appreciated.
Old 05-16-2019, 05:14 AM
creativecontrol's Avatar
Please personal message me and I will make sure support gets you taken care of.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-16-2019, 07:38 AM
EddieJones's Avatar
We found an error in the licensing system and have fixed it now. This should not happen for the next release.
Old 05-21-2019, 09:29 PM
Serge Perron Serge Perron is offline
Same issue here (S6 M10). CS case initiated. S6 unusable until fixed. When will the next release be?
Serge
Old 05-22-2019, 05:15 AM
Anyone who needs assistance please PM me with your case number and we will make sure it gets sorted.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-22-2019, 05:45 AM
itsmemagic itsmemagic is offline
Are only S6 M10 modules affected by this or M40 as well?
Was going to do the update today, but it would probably be smart to open support ticket first; we can't afford any downtime.
Activation Error - Pro Tools 12 adamen Licensing & Accounts 6 02-20-2017 10:40 AM
Pro Tools 11 activation error-licensing service not running error message Seismic Sound Windows 5 03-23-2015 05:35 AM
Pro Tools 8: Activation code not working/Error: Data Error (cyclic redundancy check) Mattmattmatty Windows 2 05-01-2013 04:26 AM
Activation Error! Pateb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-28-2008 04:55 PM
