Old 10-30-2022, 02:11 PM
paulo m's Avatar
paulo m paulo m is online now
Default Protools 2022.10 HD Driver wrongly labelled after install
after installing PT HD driver 2022.10 along wit the same PT version, Sys Info/software/extensions shows the Digidal.kext file as 2022.9
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
Old 10-31-2022, 06:19 AM
creativecontrol's Avatar
Default Re: Protools 2022.10 HD Driver wrongly labelled after install
Greetings,
There were no changes to the HD Driver released with Pro Tools 2022.10 from 2022.9. In the future, we will try and update the HD Driver version to match the Pro Tools version.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 10-31-2022, 08:35 AM
paulo m's Avatar
Originally Posted by creativecontrol View Post
Greetings,
best,
Jeff
Thanks for clarifying Jeff.
Do you have any idea on why HDX is not available anymore to use as output device in the DAPS or shows up on Audio MIDI setup when PT is closed or the Playback Engine is other than HDX?
Since version 2022.9, HDX has mysteriously vanished for other uses except for PT, so I can´t use it anymore as my output on the DAPS Renderer for example. Had to reconfigure everything with the PT Audio Bridge, before I could have the audio outs from the Renderer straight to DADman using HDX, not anymore...
Posted on Dolby forum as well, but they don´t know either.
Best,
Regards,
Paulo M
Old 10-31-2022, 08:42 AM
That certainly sounds like the HD Driver loading conversation. Have you gone through everything in the knowledge base?
https://avid.secure.force.com/pkb/ar...n-macOS?retU_7
Also, have you tried to launch the Avid Audio Server manually? May not be a bad idea to try creating a new Admin User on your machine as well and see if things improve.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 10-31-2022, 09:27 AM
paulo m's Avatar
best,
Jeff
Hi Jeff, thanks,
yes, I followed all the best practices on the article, except I never tried to launch the AAS manually, as the HD Driver shows up as loaded on Sys Info/Software/Extensions (Digidal.kext) and it works perfectly with PT and the HDX card too. I uninstalled the HD driver and reinstalled as well. Only happens since V 2022.9, was working perfectly before that. I suspect has something to do with the new Aux features launched with 2022.9, but it´s obviously just a coincidence. It seems that PT does not release the HD driver properly when the PB Engine is set to DAB or other.
Regards,
Paulo M
Old 10-31-2022, 09:37 AM
paulo m's Avatar
Originally Posted by paulo m View Post
Hi Jeff, thanks,
Here´s a link to the Dolby forum thread that I posted about this:
https://professionalsupport.dolby.co...=1667233676938
Regards,
Paulo M
Artist-Back and Play EuCon command that is visibly labelled on the dock should work? wickett Avid Pro Mixing General Discussion 2 10-05-2022 02:58 PM
Install Issue W10 & PT Studio 2022 nymills Windows 12 09-09-2022 02:24 PM
003Rack driver still OK with Pro Tools 2022.4 and 002Rack on Win 10? Tubthumper Windows 15 08-02-2022 06:06 PM
protools 9 full install no driver found for my 002? broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-14-2010 09:06 AM
