Old 07-18-2016, 10:20 AM
Bydy Bydy is offline
Default S6 v2.2 and Layouts
I'm trying to get back to the way we were working before upgrading to v2.2, and I can't figure out what I'm doing wrong.
We have 32 faders. Faders 1-16 are used in a layout to hold VCAs which are then spilled into the spill zone. The spill zone is faders 17-32.
I created the layout, there are no channels in the layout past fader 16. The first time I select the layout it's fine. Then after spilling a VCA master into the spill zone I can't "unspill" the faders from 17-32. From that point on all of the layouts display into the spill zone instead of faders 1-16.
Thoughts?
MacPro 3.5GHz 6-Core/64GB
PT11.3.2, S6 2.2
Old 07-18-2016, 11:22 AM
creativecontrol's Avatar
Default Re: S6 v2.2 and Layouts
Greetings,
If an L Spill or R Spill switch is lit white, when you recall a layout it will recall into that particular zone and not a 1-1 global layout. Is this what you are seeing? Use SHIFT + L Spill or R Spill to collapse the zone.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-18-2016, 11:34 AM
That was it.
Thank you!
Old 10-22-2017, 04:13 PM
Schottlandru Schottlandru is offline
Originally Posted by creativecontrol View Post
Greetings,
Jeff
A facility I freelance at has recently updated their S6.
Today I couldn't spill most of my layouts to the R spill zone. It kept jumping back to normal banked tracks. There was exactly one layout in my template that was assignable.
Any idea what was causing this? I used to be able to spill my VCA master layout (resulting in empty faders) and nudge/bank that through to move the vcas visibly within the zone.
Seemed like spilling the layout got an error and jumped straight out of it.
Any changes in recent software?
Old 10-23-2017, 02:15 AM
... will post a new topic since this is pretty old - sorry!
Layouts Peter Baird Avid S1, S3, Dock and Control App 4 07-05-2016 02:04 AM
Layouts are disappearing amolin Avid S4/S6 2 05-14-2016 07:34 AM
Layouts beyond modules brdst Avid S4/S6 4 09-23-2015 11:27 PM
Layouts Reckless Erik Artist Series 6 09-17-2013 07:21 AM
Layouts In Flux Dsturzy VENUE Live Sound Systems 0 03-16-2013 07:27 PM
