Old 07-01-2020, 07:49 AM
ViciousLullabyz ViciousLullabyz is offline
Default Monitoring with Avid Control and DADman
Hi
I started setting up my MTRX Studio using DADman and have programmed all the Sources, Outputs and Folddowns I want.
When DADman is in focus, I can select all these on my iPad in the Dock using the Avid Control App. However when I switch to the Pro Tools window and the DADman software is no longer in focus, all the monitoring options get lost.
How can I make them stick? And does DADman need to be running all the time as well, just like EuCon for all the controls to work?
Old 07-01-2020, 07:56 AM
creativecontrol's Avatar
Default Re: Monitoring with Avid Control and DADman
Greetings,
Go to EuControl > Assign > Lock to Application: Monitor and Control Room while DADman is focused.
Yes, you need to have DADman running to take advantage of the Monitor Profile (Pro|Mon) functionality.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-01-2020, 08:01 AM
Greetings Jeff,
Thanks for the quick answer! Working perfectly! :)
While on DADman: Is there any way to custom label the speakers?
Can I for example call it LFE instead of Low freq. effect 1.
That is its designation in the DADman monitor section, but I can't seem to change it and it gets cropped on the Avid Control App.
Old 07-01-2020, 08:21 AM
Not currently. Renaming fields is currently possible on S6 (WSControl) controlling MTRX or MTRX Studio however. I'll defer to Eddie on the possibility of adding that same functionality to EuControl.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-19-2021, 06:08 AM
diane diane is offline
Hello!
I have a question too, regarding Dadman and Avid Control.
Pro Tools runs on my main computer and DADman on a second computer. I have installed Eucon as an external workstation on the second computer, I configured to lock DADman software to the monitor section like you described and it works fine ... Until I have to shut down and restart my computer like I do everyday. At restart, Eucon finds Pro Tools perfectly without doing anything, but the second workstation is unassigned and detached (even though this second computer is never shut down). Everyday I have to manually re-attach and lock the monitor again.
Could you please tell me if there's a way of keeping the configuration after reboot ?
Thanks a lot !
Diane
Old 08-20-2021, 08:27 AM
EddieJones's Avatar
I'll test that here and see if its a bug
Old 07-31-2023, 02:49 PM
briansin briansin is offline
Just curious if this ever got resolved? Does the machine that never gets shut down need to be the main instance and the Pro Tools workstation the External? Or does this work now?
Thanks
Most Waves plugins cannot be set properly from Avid control surfaces / Avid Control? XJENSEN Avid S1, S3, Dock and Control App 3 08-11-2022 06:59 AM
Control/DADman flakiness LukeHoward Avid S1, S3, Dock and Control App 6 10-09-2021 05:22 PM
DADman disconnects pkingduk Pro Tools HDX & HD Native Systems (Mac) 12 07-26-2020 04:22 AM
DADMAN and Protools on 2 Separate Computers EUCON PT|CONTROL Mr Base Avid S1, S3, Dock and Control App 2 08-03-2019 11:06 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
