Old 01-24-2020, 10:45 PM
basehead617 basehead617 is offline
Default Possible S6 bug with HEAT controls?
I spent some time demoing an S6 today and noticed what seemed to be a minor bug but I’m not sure if it’s intentional or not or if there are more examples of this happening elsewhere..
- put it in ALL mode
- hold Insert on a process module to get HEAT settings
- press Opt and turn Enable knob so all channels have HEAT enabled
- i played around a bit unrelated to HEAT
- press Opt and turn Enable knob to disable HEAT on all channels, but it only disabled it on the channel I was turning it on
I repeated this several times to make sure it wasn’t a fluke.
It was a bummer because i then had to go in and turn it off manually for 40+ tracks..
Since i don’t have access to it anymore I can’t really check anything else but seemed worth reporting.
According to the owner this was all latest software.
Old 01-25-2020, 08:14 AM
creativecontrol's Avatar
Default Re: Possible S6 bug with HEAT controls?
I’ll take a look, however S6 doesn’t automatically adhere to all of the OPTION modified actions that you can perform from the software interactions. I suspect this is not specific to HEAT controls.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Pan Controls MarkEdgeller Avid S1, S3, Dock and Control App 0 09-25-2015 03:20 AM
HEAT controls are missing on first boot midnightrambler Pro Tools 12 13 07-14-2015 08:11 AM
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
sci fi controls bonehead696 macOS 1 09-02-2013 09:37 PM
MAC controls PC , PC controls MAC, wireless crazy stuff....you got to have it... lucian Tips & Tricks 7 12-13-2000 11:20 AM
