Old 07-27-2022, 03:46 PM
Armando Armando is offline
Default HD Digital IO and PCM 81
Curious, does the Avid HD Digital I/O allow you to connect a Lexicon PCM 81 via AES and will it allow for SRC in a Pro Tools session set at 24/96 considering the PCM 81 is 24/48?
Thanks!!
Armando
Old 07-27-2022, 05:54 PM
LukeHoward LukeHoward is offline
Default Re: HD Digital IO and PCM 81
Thanks!!
From memory the SRC is only on the HD I/O's inputs, so you would need an external sample rate converter like the z-link96 to sample rate convert the revere send. I used to do this with my Quantec 2402...
https://lukehoward.com/
Old 07-28-2022, 05:21 AM
creativecontrol's Avatar
Yes, that is correct.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Power consumption of the 192IO Digital and HD IO Digital Alécio Costa Pro Tools TDM Systems (Mac) 32 10-26-2014 10:55 PM
Newbie Digital IO question - HD Digital i/o vs 192 Digital vs X-HD mrdosun Pro Tools 10 1 02-16-2012 11:20 PM
Tascam Digital / ADAT Digital Conversion Vyper_Mk_II 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-23-2002 02:54 AM
If I get PTHD can I hang all my 44/48k digital gear off of a 192 Digital I/O? Jules Pro Tools TDM Systems (Mac) 11 06-21-2002 06:57 AM
Digital Output from 888/16 isn't compatible with Digital Input of TC M2000 & PCM 80 beerbr Pro Tools TDM Systems (Mac) 0 11-02-2000 08:01 PM
