Old 04-21-2021, 05:24 AM
garret garret is offline
Default S4 no expand available under config section
Hi
As the thread title implys I am trying to set up attention expand zones on my 24 fader s4. The manual states to go to settings, surface page and then press config and then expand. However when I press config the only options are surface, Lspill, Rspill, display and cancel. No expand.
Any ideas?
Thanks
Garret
IMDB
Old 04-21-2021, 06:49 AM
creativecontrol's Avatar
Default Re: S4 no expand available under config section
Greetings,
Do you have a bucket on your S4 with option modules - including one or two Knob Modules for example?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 04-21-2021, 09:52 AM
Hi Jeff
Aha! I think you may have solved the problem. I didn't realise it only works on the option modules. I just have 24 faders and master module and the panner option.
Thanks for the reply.
Garret.
IMDB
Old 04-21-2021, 10:36 AM
Yes, correct. For On Attention zones you need to add option knobs and then choose the appropriate surface stack when configuring your console.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 04-21-2021, 11:36 AM
basehead617 basehead617 is offline
best,
Jeff
Thanks Jeff this is great info I didn't know..
So on S4 you can't use the knobs of the CSMs in a split configuration for example to be your 2 (L / R) attention knob zones? (You can do this with 2 knob modules on S6)
Old 04-21-2021, 12:58 PM
For On Attention workflows -> S4 can address up to 2 dedicated Knob Modules installed into one "options" bucket in the frame. Yes, S6 has the ability to declare in line knob modules as attention knobs or, like S4, dedicated knobs in their own bucket.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
expand rbsalyer Pro Tools 9 1 10-30-2016 06:38 AM
How to get PT to loop a section, without having to listen to that entire section? FranHoop Pro Tools 9 3 11-04-2011 02:57 AM
What are you using to expand your 003 I/O? poaprex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 05-31-2008 09:48 AM
RECORDING SECTION BY SECTION jayrussell Tips & Tricks 3 04-28-2008 10:59 AM
Where is Expand!? MarkGriffith General Discussion 5 02-15-2006 03:27 PM
