Old 02-06-2024, 06:23 AM
jimmiplex jimmiplex is offline
Default S6 causing protools pan window delay/lag
When I am connected to an S6, I am having an issue where the pan window in protools is very laggy, and it takes a while before I can select different pan parameters to change, and when I do, the resolution tends to be a bit choppy. If I try to change a parameter before the blue square appears (showing that parameter is up on the S6 master module channel strip), nothing will change, and it takes about 3-5 seconds for it to highlight, sometimes longer after changing parameters. I have a second mix machine and s6 this is happening with, too. Has anyone run into this before?
I am running PT 2023.9 on macOS 12.6.9, Eucon and S6 software 2023.11.0.121, but I have tried Eucon 2022.9.0.44 as well on an intel 12core 2019 Mac Pro, in satellite link with another mac pro in the same config.
Thanks!
Old 02-06-2024, 02:31 PM
creativecontrol's Avatar
Default Re: S6 causing protools pan window delay/lag
Is this interaction specific to Pan, or can it happen with Sends, EQ, Dyn or general plug-in interactions? Are your attention preferences set to be keyed from Pan and other functions clicked in the DAW?
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-16-2024, 01:30 PM
Hi Jeff,
We discovered it seems to be a bug between Protools, (specifically running S6 or some Eucon enabled device), and simultaneously having Altiverb 8XL plugin windows open. The more Altiverb 8 plugin windows are open at a time, the worse it is. Once the plugin windows are closed, the problem goes away. It seems to mostly be affecting the pan window, I wasn't finding any other places affected, but it makes the pan window very difficult to use.
Old 02-16-2024, 03:21 PM
I'll take a look. Can I ask how many instantiations of Altiverb you have rolling in that session?
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
I/O setup window causing freeze. brycar44 Pro Tools 0 07-25-2021 09:19 PM
Automation Window workflow causing audio delay after use? krmsound Pro Tools 2019 0 09-06-2019 11:07 PM
Delay Compensation Causing Buses to distort ralfddd Pro Tools TDM Systems (Mac) 1 10-20-2009 07:41 AM
Mod delay causing crash... MYEARSBEATURGEAR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-03-2007 03:03 PM
... delay a plug-in is causing? jbr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-09-2006 06:56 PM
