Old 04-23-2018, 05:40 AM
innenhofstudios innenhofstudios is offline
Default Monitor Knob - Cut Assignment like XMON but now for MTRX
How can i cut the Monitor Path on the MTRX like it is for the X-Mon ?
Sure there is a way through the Submenus on the Montor Prefs.
Is there a way to program thios knob ?
Best René
innenhofstudios.at
S6 M40-16, MTRX, 2xHDX, OS10.12.6
www.innenhofstudios.at
Old 04-23-2018, 06:13 AM
creativecontrol's Avatar
Default Re: Monitor Knob - Cut Assignment like XMON but now for MTRX
Greetings,
This is currently possible to cut and dim any of the 4 monitors plus Control Room from the monitor soft keys. You can find Control Room from the EXTRAS section on the right Automation Module or simply by pressing the QuickJump for Monitoring with is SHIFT + numeric section "." - period.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-04-2018, 07:54 AM
Originally Posted by creativecontrol View Post
Greetings,
Jeff
Thank you for your response Jeff, but still this way is not handy at all. The Mute Version like for XMon will never be possible ?
Old 05-04-2018, 07:22 PM
its2loud its2loud is offline
What are you asking exactly? Currently on the S6 there is a MAIN Cut and Adjustable Dim for any selected speaker set. You want separate cut and dims for each of the selectable speaker paths or sources to the speakers?
The Matrix is highly flexible depending on how outset it up. Also, if you deselect a monitor source on the MTM it will Cut that signal to the output.
Are you trying to send different signal to difference speakers or headphones in different rooms? It would help if you clarify what you want to be able to do.
Old 05-07-2018, 01:46 AM
Its actually a very simple task. nothing really special...but very handy.
ok. on the XMON im able to cut Mon A and Mon B from the S6 surface right from the surface. With no Submenu etc. The Top Knob right to MonA and MonB showed Red when it was Cut.
With the Matrix i have to go in the Submenus to Cut Monitor Path A-C.
Im not talking about Speaker Sets. Only about the Monitor Paths and to mute/cut them with the knobs on the S6.
I hope i was clear now ?
Old 05-07-2018, 03:02 PM
Strange! I see what you mean. There doesn't seem to be a way to customize the depress function of the control knob next to MON A and MON B selector. The Main Monitor Depress works to Cut the Mains and Talkback works to latch the TB. There has to be a way to assign that knob depress to CUT based on the MON A or B Selection. Even the document says the knobs do this. Jeff, can you guys fix this to work with the DADMan?
File Type: jpg Screen Shot 2018-05-07 at 3.18.04 PM.jpg (33.3 KB, 0 views)
Old 05-08-2018, 05:07 AM
Greetings,
Yes - this has certainly been reported previously with regard to lack of parity for XMON when MTRX is used instead:
Push to mute for Control Room and Monitors A-D
Color coding for Control Room and Monitors A-D to indicate mute/cut.
Listenback Support / 2nd TB, toggling, enabling
Eddie is the product manager for S6 so he determines what gets implemented.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-08-2018, 06:19 AM
Greetings,
best,
Jeff
Ok. Thanks Jeff. So how do we let Eddie know and get this moved up the “to do”list. Seems like you guys are aware of it?
Old 05-11-2018, 10:04 AM
He does monitor this forum however I will also copy him via email on the thread.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-12-2018, 08:02 AM
[QUOTE=creativecontrol;2487943]He does monitor this forum however I will also copy him via email on the thread. /QUOTE]
That’s great! Thanks Jeff
Custom parameter to knob assignment RyanC Avid S1, S3, Dock and Control App 2 06-22-2016 03:42 PM
MBox 2 Pro Monitor knob has stopped changing monitor levels Rumandolin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-21-2013 09:13 AM
Structure Free smart knob assignment questions Gothboy Virtual Instruments 3 05-02-2008 01:35 PM
Structure Free smart knob assignment issue Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-09-2008 05:58 PM
Monitor out togheter with monitor volume knob kennylovrin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-22-2006 08:19 AM
