HDX Thunderbolt 3 Chassis
Does anybody know if it is possible to fit an HD Native pcie card into the new Thunderbolt 3 Chassis. All of the blurb on the website etc, suggests that you need an HDX card, but I cant imagine why an HD Native card would not work, given that it is just a pcie card. Am I right to assume that the likely reason Avid dont refer to it, is just that they dont support the card any more. Or is there something I am missing.Cheers,
CP |
Re: HDX Thunderbolt 3 Chassis
The HDN PCIe card was not explicitly tested in the HDX TB3 chassis, but based on feedback from customers it appears to be working fine.
best, Jeff |
Jeff do you have any feedback about Sonnet Echo Express TB3 edition and HD Native PCIe? I want to use TB3 connection without adapter TB3->TB2.
PT Ultimate HDX system PT Ultimate HD Native system Last edited by pl007; 09-02-2020 at 08:16 AM. |
Here’s the grid of explicitly what we have tested and what combinations are recommended:
https://avid.secure.force.com/pkb/ar...-Compatibility Jeff Sent from my iPhone using Tapatalk Pro |
Could you explain why Sonnet Echo Express III-D TB3 edition required downgrade to TB2 card and Apple TB3->TB2 adapter with iMac 19.x?
While Sonnet Echo Express III-D HDX edition can work with iMac 19.x via TB3.
PT Ultimate HDX system PT Ultimate HD Native system |
Exactly, does anyone know what the difference is between the original Sonnet TB3 Interface Card and the Avid TB3 Interface Card?
From what I gathered from a quick discussion with Sonnet Tech support, the HDX issue is related to the combination of the specific TB3 bridging chip and the TB3 interface card used in the TB3 version of the Echo Express III.
A TB3 Echo Express III with a downgraded TB2 interface card works fine. A TB2 Echo Express III upgraded to a TB3 interface card works fine. I have never looked at one closely, but I suspect the Avid TB3 enclosure is probably pretty similar in design to the latter, running an older bridging chip with the new interface card. I noticed Sonnet recently discontinued the Echo Express III and replaced it with the 'Echo III', perhaps because of these issues. The new Echo III includes a specific "HDX Mode" that appears to limit the enclosure to PCIe 2.0 performance.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Sonnet Echo Express III-D/R Thunderbolt 2 chassis uses PCIe 2.0 backplane, whereas Thunderbolt 3 uses PCIe 3.0 backplane.
The HDX version uses the PCIe 2.0 backplane with a Thunderbolt 3 upgrade card.
Using a thunderbolt chassis | jeremyseanbell | Pro Tools HDX & HD Native Systems (Win) | 16 | 02-10-2016 04:34 AM |
HD native thunderbolt through Echo Express SE Thunderbolt Chassis | hkj1 | Pro Tools HDX & HD Native Systems (Mac) | 1 | 11-06-2013 05:49 PM |
Thunderbolt Chassis to PCIx Chassis for TDM Laptop Rig | Logichead | Pro Tools TDM Systems (Mac) | 0 | 06-09-2013 01:42 PM |
Thunderbolt-Sonnet’s Echo™ Express PCIe 2.0 Expansion Chassis with Thunderbolt™ Ports | Barry Johns | Pro Tools TDM Systems (Mac) | 29 | 08-11-2012 07:01 AM |
Another way to do chassis's....thunderbolt! | bashville | Pro Tools TDM Systems (Mac) | 10 | 05-02-2011 03:00 PM |
