Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 01-27-2020, 04:46 PM
creativecontrol's Avatar
Default Re: Question re MTRX digital insert point
The point being, if you were expecting, and therefore assigning in the IO setup of Pro Tools an output feed to the Bricasti using 15-16, it’s never going to get there based on your screen grab.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-27-2020, 05:24 PM
SomeOtherGuy SomeOtherGuy is offline
I guess I'm just not understanding the routing protocols here; are you saying I should keep the routing to 7 & 8, same as the physical routing? I tried that but it didn't work (could be a clocking issue coming into play too). Thanks.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 01-27-2020, 05:31 PM
According to your shared screen grabs...
Out of Pro Tools outs 7-8 which is feeding AES snake #2 channels 15-16.
Into Pro Tools on inputs 15-16 which is coming from AES snake #1 channels 7-8.
Is this what you intended to do?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-27-2020, 05:57 PM
Okay, I just switched the routing to match the AES physical routing and now it works. I had already done this at the start of all this, so not sure why it's working now, perhaps a clocking issue resolved.
Last question is, I take it analog channels 7 & 8 will no longer be available, as I'm using digital 7 & 8. AES input usage takes away from analog inputs?
Old 01-28-2020, 12:29 PM
K Roche's Avatar
K Roche K Roche is offline
I don't use MTRX I have an OMNI HD I/O
I am doing the same thing running My Bricasti via AES
With mine the answer is no it does not "take away" from the analog channels, Omni only has 4, but does subtract from the total I/O available, 8 in 10 out, so physically it is routed in 5-6 in the I/O matrix but (shows as AES 1-2 ) As you see Analog 1 through 4 are still available . Here is a screen shot
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #16
Old 01-28-2020, 01:00 PM
Regarding resources. With a MTRX connected fully to a HDN or HDX engine card, the user has 64 channels of IO to route to and from Pro Tools without adding additional DigiLink expansion cards.
A single MTRX unit supports up to 6 analog cards per unit. For example - 24 channels of analog IO using 3 AD and 3 DA cards. So, even with the factory DigiLink, users still have the ability to route more than 32 digital channels in and out. It should also be clarified that you the user determines the correlation between the IO resources in MTRX / DADMan and how those are served to Pro Tools via DigiLink using the routing interface in DADman. If you want to allocate the first 32 channels of IO coming from MTRX to Pro Tools as Dante, you can certainly do so. All of the populated flavors of analog and digital IO are available for custom user patching in or out of DigiLink connections to serve Pro Tools.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
How to go from Apple TV digital out to MTRX? SomeOtherGuy Pro Tools | MTRX & MTRX Studio 55 02-08-2020 02:52 PM
How do Insert an in point and out point in my tracks and play this as a loop. scottee Windows 2 08-15-2012 08:08 AM
Playback starts wherever I make a selection or any insert point asuanlarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 04-03-2009 01:24 PM
Not using the first insert point Paul Maunder Pro Tools TDM Systems (Mac) 1 04-06-2007 03:47 AM
DNS 2000 Best Insert point? Mubeau Post - Surround - Video 5 11-12-2005 04:26 PM
