Old 08-23-2018, 07:30 PM
EddieJones's Avatar
Default Re: Process Knobs Slow to Load
Thnaks..I'll pass on to QA test to look at now.
Old 01-22-2019, 01:26 AM
[email protected] mjr@du.se is offline
I'm seeing a similar issue with out S6 M10 (16 faders on version 18.3.244) controlling three Avid PRE. Switching all Process Knobs to Input will change 1-2 channels strips immediately, 1-2 channels a second or two and then pause for several seconds before changing the others.
We're using with Pro Tools 2018.12.
Old 03-21-2021, 09:50 PM
basehead617 basehead617 is offline
Originally Posted by hixonjames View Post
Eddie,
I think you're on to something about it having to do with the Pre's...
I made a new session with 80 mono audio tracks. I put an Avid Channel Strip on each channel. I set all the inputs to a single bus.
With this setup (and 'All' engaged), all functions, including input, load in equal time - about 7 seconds. When I assign the tracks to individual inputs with pre's assigned, loading input takes around 45 seconds.
If I change all the inputs from one configuration to the other, not all of the knobs will fully change to the new configuration - they just go blank. Most will show correctly. This behavior is the same with eq and dyn.
I don't know if it's useful to know, but the status graphs for the process modules only peak at about 1% CPU, and memory and network are steady at 16.7% and 0.0% respectively.
Also, this hasn't been an issue before. Only since upgrading to Pro Tools 2018.7.
Was this ever solved? (don't use PRE but may soon)
Old 03-23-2021, 11:36 AM
creativecontrol's Avatar
I'll have to have another chap take a look at this as I don't currently have a Process module online.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Eucon 3.3 Very Slow To Load simonjewel Artist Series 0 08-10-2015 04:48 AM
Pro Tools very slow to load bus ericsvizeny Pro Tools TDM Systems (Mac) 2 11-16-2010 09:27 PM
Sessions Very Slow to Load WilberForce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-09-2010 11:11 AM
Slow to load jkeefauver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-01-2007 02:01 PM
URS Plug-ins slow to process in Audio Suite Third Eye Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-20-2004 07:59 PM
