Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 01-21-2021, 04:32 PM
markprator markprator is offline
Default Clocking errors on Pro Tools Carbon - UPDATE
Has anyone had clocking issues using (2) external ADAT(Lightpipe) devices?
encountering errors using (2) Midas XT48 sending audio via ADAT, clocked from Pro Tools Carbon interface.
If you're not using a similar configuration, please don't respond. Thanks!
UPDATE: THE ERRORS ARE BACK!!!
Old 01-21-2021, 04:55 PM
LukeHoward LukeHoward is offline
Default Re: Clocking errors on Pro Tools Carbon
I am not using a similar configuration so, please feel free to ignore the response below.
How are you distributing clock from the Carbon to the Midas? ADAT or word-clock? Have you tried making the Midas the clock master (see page 22 of the manual)?
https://lukehoward.com/
Old 01-21-2021, 06:05 PM
Tried every configuration available:
Carbon - master, daisy chain WC to Midas 1 and 2
Carbon - master, split word clock to Midas 1 and 2
Midas #1, master, daisy chain to Midas #2, then to Carbon as WC slave.
Adat as clock source from Midas 1
Adat as clock source from Midas 2
WC terminated and non-terminated.
In all instances, interfaces and preamps show green (good) clock.
This is a new system, new Mac mini (running Catalina 15.10.7)
So far, no success with Sweetwater or Avid. back on the phone tomorrow am.
Old 01-21-2021, 06:12 PM
You might get better help describing what problem you are having? Clicks? No signal at all? What sample rate are you working at?
Old 01-21-2021, 06:41 PM
creativecontrol's Avatar
Greetings,
I believe I was in communication with your associate. This was the configuration that we recommended testing with the MIDAS XL48 units:
MIDAS 1 (master) Word Out to -> Word In on MIDAS 2 (ext clock)
MIDAS 2 -> Word Out to Carbon Word Clock In.
Route ADAT from each MIDAS unit to ADAT inputs on Carbon.
In Audio MIDI Setup -> for Clock Source under Pro Tools | Carbon – reserved for Pro Tools: Choose Pro Tools | Carbon: Word Clock In 1-28.
Please let us know.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-22-2021, 02:59 AM
thanks, Jeff. Tried that a couple days ago. Also did the update yesterday, and no luck. Most likely will be in communication with you today at some point.
Old 01-22-2021, 03:02 AM
Thanks, Darryl. Clocking errors in the form of pops and clicks. Kinda like static. happens more at 48k than at 44.1. I'm wondering if it's not the Midas preamps. I was posting to find out if there was anyone out there with the same setup. I've been told there was.
Old 01-22-2021, 07:26 AM
Default Re: Clocking errors on Pro Tools Carbon - UPDATE
After conversation with Avid Jeff, troubleshooting uncovered a possible defective optical cable.
Isolated bad optical cable, awaiting arrival of new cable. Midas preamp #1 working with no clocking or audio issues
Thank you Avid Jeff for your time.
Old 01-23-2021, 10:59 AM
Default Re: Clocking errors on Pro Tools Carbon - FIXED!
after receiving new lightpipe cables and installation,
re-configured word clock to reflect carbon as master clock,
system clocking correctly, no artifacts and all 16 external inputs.
Thanks again, AVID Jeff!!!!
Old 01-27-2021, 06:39 AM
looks like the errors and artifacts are back......
URGENT HELP NEEDED, Clocking cause assertion errors MrBibidy macOS 0 06-19-2012 10:49 AM
More errors when clocking from external AD/DA...DIGI PLS HLP req06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-28-2008 10:47 AM
G5 optical into 192 - Distortion & Clocking errors Polaris Post - Surround - Video 12 11-22-2006 11:10 AM
Clocking errors , need help!! JasonAaronAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-17-2004 06:46 AM
