Old 07-23-2020, 03:46 AM
kava kava is offline
Default Choppy panning in half-speed mode
I see and hear very choppy / fragmented automation written to the timeline
when panning with the s6, while protools is in half-speed playback mode (Shift-Space)
happens only on larger format tracks involving height (atmos, 7.1.2, 7.0.2, etc..)
PT 2020.3 and .5
S6 Version 19 and newly updated 20.6
anybody else?
Mac Pro 2019 16-Core, 144GB Ram, OS X 10.15
ProTools Ultimate, 2x HDX
NTP Penta720 I/O + 192 HD I/O + SSL Madi Link
Sync HD, Dolby Atmos RMU
S6 - M40 - 32channel.
Filmpost at cosmix studios vienna
http://www.cosmix.at
http://www.tom-kava.com
Old 07-23-2020, 06:20 AM
creativecontrol's Avatar
Default Re: Choppy panning in half-speed mode
Greetings,
Can you let us know the specs of your primary workstation and OS version please?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-05-2020, 02:02 PM
hi jeff,
i‘m still on sierra 10.12.6 with PT 2020.5 on a trashcan 2013 macpro.
eucon workstation and s6 on latest version (20.6).
will try to post a screenshot of the automation soon,
tom
Old 10-28-2020, 08:05 AM
Hi Jeff,
I am on a new machine now,
Mac Pro 2019, 10.15.5,
PT 2020.9.
S6 + WS Control 20.6.1.3
I again have massive problems when panning half speed, especially Atmos, which I need very often. This is a real problem here. since I cannot check every automation pass visually on all automation lanes - but I sometimes "lose" the red dots under my fingers - like they won't follow my movement and the atmos objects start jumping in the dolby Monitoring application.
I attach a screen shot of an automation pass.
S6 is connected to a switch thats connected to the second Ethnernet port on the Mac Pro. Theres only my Penta 720 on that switch (Eucon Monitoring) no other network devices that could disturb.
greets thomas.
Old 10-28-2020, 08:06 AM
heres the screenshot:
Old 10-30-2020, 05:28 AM
I've kind a found the problem.
If the pan link is activated and both pan-dots of a stereo track are touched the link is normally overruled and the dots can still be panned individually.
This does not work in 7.1+ panners -> the pan-points jump between the point that is touched on the screen and the "linked" position where it should go when only one side is touched. this happens always in half speed mode. and sometimes at normal playback tempo.
btw. why do I have to "catch" the pan point on the s6 touchscreen? why can't I just touch somewhere on the screen and the dot jumps there?
this is EXTREMELY annoying.
Old 10-31-2020, 11:48 AM
I'll take a look at these behaviors over here shortly. Thanks.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-01-2020, 10:00 AM
Are you performing this from a Master Module or from a Joystick Module? If the Master Module, are you observing the touch circles around each of your fingers are red for the entirety of the automation pass?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-02-2020, 01:31 AM
Hi Jeff,
from the masters modules touch screen. they stay red all the time and have the second red ring around them. but it sometimes looks as if they "would travel behind", they lag, look delayed.
Half way through LP mix -Panning settings not matching audio pan PT12HD. Please Help Beau_McKee Pro Tools 12 3 02-23-2016 06:37 PM
recording at half speed... montreal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-07-2011 03:22 AM
half speed the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-02-2008 04:27 PM
PTLE & half-speed record mode; Click goes batty!!! max cooper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-17-2005 07:05 PM
shortcuts for half speed +dbl speed recoring neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-09-2003 02:48 PM
