Old 01-07-2021, 05:15 AM
creativecontrol's Avatar
Default Re: Accessing Talkback Mic post-TB switch
I added a Tech Tip to our YouTube playlist to show how to set this up.
https://youtu.be/oj5mYPFa2Qw
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-07-2021, 08:28 AM
Thanks Jeff - been using this now for a few months to feed talkback into a remote session, and to feed monitor wedges on livestreams - very handy!
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 07-08-2021, 06:40 PM
CD Productions CD Productions is offline
Hey Jeff, I followed your video, and was able to set up a TB in PT that would respond to the Talk switch on my S6. That said, I also have a client mic in my studio. The mic on the S6 is input into the MTRX Studio mic/inst input 1. The client mic, which has a momentary switch is plugged into mic/inst 2 and the switch connector on the MTRX Studio. TB 1 is routed to DigiLink 1, ch 17. Client mic is routed to DigiLink 1, ch 18. They are set up in the Monitor section as 2 separate outputs. In PT, I created 2 separate Aux channels, one fed by 17 in for TB 1, and the other with an input from 18 for TB 2. Here's the problem, when I hit talk for either mic, it's feeding both 17 and 18 inputs to both aux channels. Any ideas why that would be happening?
Charles Dayton, CAS
Twisted Avocado Post Audio
http://www.imdb.com/name/nm0206743/
Old 07-09-2021, 09:18 PM
BTW, thank you for posting the instructional video to begin with. It was very helpful.
Charles Dayton, CAS
Old 07-11-2021, 12:09 PM
Did you create a Mono or a Stereo Output from the Slate Monitor created in the DADman monitor profile? In my example -> I have a mono output using DigiLink 1- 13.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #16
Old 07-14-2021, 04:20 PM
They are mono. Going out DigiLink 1 17 and 18 respectively.
Charles Dayton, CAS
  #17
Old 07-15-2021, 04:55 AM
Perhaps take a snap of these monitors in your profile and we can troubleshoot it better.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #18
Old 07-16-2021, 11:29 AM
I keep getting this message when trying to upload screenshots.
Access Denied
You don't have permission to access "http://duc.avid.com/newreply.php?" on this server. Reference #18.570be8ac.1626460128.3b3ab7b
Charles Dayton, CAS
  #19
Old 07-26-2021, 05:32 AM
Not sure on the DUC attachments. You can certainly use DB, Google or other file sharing service to post the images.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #20
Old 02-26-2024, 03:51 AM
patmaki patmaki is offline
Hi Jeff, thanks for the instructions on setting up TB. The part of the concept I'm having trouble grasping is why would the Mic be on the Output. In other words, how does the routing know what the source (channel) the mic is on if that's not defined under source in the monitor setup in DADMan?
Building a talkback switch mesaone General Discussion 4 02-14-2015 03:38 PM
External talkback mic/switch/cuelight switch Pete Gates Post - Surround - Video 3 03-16-2011 01:53 AM
Pro Control Talkback switch GrantFM ProControl, Control|24, Command|8 0 12-02-2009 11:44 AM
talkback switch TLarvenz ICON & C|24 1 06-06-2004 11:20 PM
Flaky talkback switch CraigLearmont ICON & C|24 1 12-16-2003 02:41 AM
