Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 03-15-2022, 10:19 PM
juanpiedra014 juanpiedra014 is offline
Default Eucon 2021.10 Unable to Install Mac M1 Monterey
Hi!
I just got my new Mac Book Pro M1 and it came with Monterrey. I had an older version of Eucon which didn't fully worked because the Artist Mix showed nothing on the display so I uninstalled it and downloaded Eucon 2021.10 Unified Installer and it says:
https://www.dropbox.com/s/1ifvqozsij...%20AM.png?dl=0
Tried everything
Old 03-16-2022, 07:32 AM
EddieJones's Avatar
Default Re: Eucon 2021.10 Unable to Install Mac M1 Monterrey
I don't see the message it says? Eucon 21.10.1 does work on this system. Make sure you are installing EuControl not EUCONWS
Old 03-16-2022, 12:37 PM
Sorry, now I put the link of the picture in the main post.
The one I am trying to install is: EUCON Workstation Unified Install 2021.10.1 (Mac) (182.06 MB)
Old 03-16-2022, 12:54 PM
EddieJones's Avatar
Thats not what to Install, you need EuControl...the top option.
Old 03-17-2022, 10:05 AM
Default Re: Eucon 2021.10 Unable to Install Mac M1 Monterey
You mean this?
https://www.dropbox.com/s/a4pbvp28f0...%20PM.png?dl=0
This is the only one i am trying to install
Old 03-17-2022, 03:52 PM
EddieJones's Avatar
OK, that is the correct check box. Can you try checking Uninstall all Apps and remove prefs options and see what happens? This could be a permissions issue. Did you accept/allow all the dialogs?
Old 03-18-2022, 08:16 PM
Tried this. Same error.
Old 03-19-2022, 09:49 AM
creativecontrol's Avatar
Greetings,
I just verified on my macOS 12.3 partition that the EUCON Unified Mac Installer 2021.10.1.29 was able to successfully install EuControl (S1/S3/Dock/Avid Control) without any issues. I would ->
Make sure you are installing 21.10.1.
Uninstall and remove all preferences.
Make sure you are on macOS 12.3.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-21-2022, 05:12 PM
Just updated to Mac OS 12.3. Erased preferences, tried to reinstall and same issue
Old 03-21-2022, 07:37 PM
I would recommend making a new Admin user on the workstation and give it another go.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
2021.12 / Izotope RX / Monterey Pete Gates Pro Tools 9 03-17-2022 11:01 AM
Protools 2021.3.1 compatibility with Monterey alfiea Pro Tools 7 02-06-2022 01:02 PM
PT 2021.10 - Monterey - M1 Max - EuCon - Joy teedeecee Avid S1, S3, Dock and Control App 3 12-09-2021 03:46 PM
PT 2021.10 - Monterey - M1 Max - Insane teedeecee Pro Tools 12 12-09-2021 04:34 AM
Has anyone tried Pro Tools 2021.7 on the Monterey Betas? off the wall macOS 28 11-17-2021 10:21 AM
