Old 02-21-2024, 07:46 AM
MirkoP MirkoP is offline
Default Protools wont play due to -22005 error
Hi everyone,
I just switched systems by installing my Native PCIe Sync HD and HD I/O on a Mac Studio M2 Ultra with OS 13.6.4, Sonnet Echo III, and Pro Tools version 2023.12.1.
Immediately after installation, I had a series of playback issues with a 9129 error.
I tried changing the Playback Engine to "built-in" and it seemed to work fine.
I tried changing the connections between the Sync HD and HD I/O by putting them in loop sync and at one point it started working again. Suddenly, however, the problems returned.
The error message now is -22005.
I have tried all the solutions I found on the internet but nothing seems to work.
Has anyone had a similar problem and knows how to fix it?
Please Help
Thanks a lot!
File Type: png Screenshot 2024-02-20 alle 19.58.52.png (33.7 KB, 0 views)
File Type: png Screenshot 2024-02-21 alle 16.44.33.png (34.8 KB, 0 views)
Old 02-21-2024, 08:05 AM
creativecontrol's Avatar
Default Re: Protools wont play due to -22005 error
Greetings,
Does your TB3 chassis have a toggle switch ->
Move Gen 3/Gen 2 (HDX) switch to the Gen 2 (HDX) position to enable
compatibility
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-17-2024, 04:53 AM
Hi Mirko! I'm getting the same thing (not your first error but the -22005 one quite frequently too since moving to a 14,8 Mac. And it's gotten worse since 24.3 Here's a related issue with the same error involved. And I don't run a chassis. Under 23.12.x it happened about once every 2-3 weeks. Now it's pretty much every morning. A friend is running an identical hardware setup as me and is getting the exact same error.
I usually get it after first turning on my rig in the morning. I then have the reboot the machine once or twice and then it works and is stable for the rest of the day.
https://duc.avid.com/showthread.php?p=2696601
Frank.
play flashes then stops. session wont play. hellbert Windows 21 03-31-2011 10:49 PM
Protools Wont Play DJLilSteve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-03-2009 02:27 AM
wierd error protools wont start DHS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-22-2007 10:43 PM
QT Movies wont play in PT7: 6088 error immediatly Sofine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-09-2006 09:54 AM
My session wont play -7401 dae error MaKoRancid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-28-2004 03:25 PM
