Old 02-11-2019, 05:39 AM
stefanboman stefanboman is offline
Default Need urgent help with Xmon
Posted about this problem a long time ago but it hasn't occurred that much lately until now.
Our Xmon is acting up big time now but I suspect it´s not hardware related.
It seems to loose or ignore most commands to switch speakers and change monitor sources.
Lets say I need to check some mixing decision in my small boombox, now I have to press that button 20 times before it actually kicks in.
Very annoying, since I do that all the time!
Its not the actual buttons since I see the S6 screen responds immediately, but the Xmons doesn't.
This affects speaker switching and source selection. i also have a folddown button that I use as a mono switch, but that one doesn't seem to be affected.
Tried restarting everything, disconnected workstation and re-connecting but not helping.
Really need to fix this ASAP as this really slows down my workflow.
Anyone experienced this before? What should I try?
Old 02-11-2019, 06:21 AM
creativecontrol's Avatar
Default Re: Need urgent help with Xmon
Greetings,
I would start with some of the suggestions in the following knowledge base article:
http://avid.force.com/pkb/articles/e...n-MUTE-with-S6
Power Cycle and Reset the XMON, plus re-seat the DB15 connection.
http://avid.force.com/pkb/articles/en_US/FAQ/en207651
On a side note, I have seen a handful of XMON hardware failures or intermittent problematic behavior over the past few months. Some of these units are nearly 15 years old. Let me know what you find.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-12-2019, 03:19 AM
Thanks Jeff!!
Took me over two hours going over things again and again but eventually things went back to normal.
Cheers!
7.1 and XMon? subwoof Post - Surround - Video 5 08-14-2017 06:43 AM
Xmon mod?? mtung ICON & C|24 0 10-01-2009 05:16 AM
XMON OKN ICON & C|24 2 01-27-2006 09:34 AM
URGENT URGENT Hard Drive problem please help arcarsenal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-28-2005 12:02 PM
HELP WITH MBOX PLEASE!!!!!! URGENT URGENT ....... YahB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-25-2003 05:30 PM
