Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #221
Old 03-24-2021, 05:31 AM
creativecontrol's Avatar
Default Re: First steps with MTRX Studio
MTRX in Focus Playlist (MTRX + MTRX Studio) on YouTube:
https://www.youtube.com/playlist?lis...QDeRgOaJw_FSI1
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #222
Old 03-24-2021, 07:14 PM
BScout BScout is offline
Originally Posted by hitp View Post
4) Is there also a way to set different Reference Levels and save them as presets. Say for 75dB, 79dB, 82dB and 85dB? I currently mix near-field at 79dB =-20dBFS RMS (my REF 0 fader level in DADMAN) for TV shows destined for streaming services in a small room. But at times you want to change as clients ask for more dynamic or less dynamic mixes.
Verses doing it with Speaker Sets as referenced on Jeff's link, I'd recommend doing it with Folddown setups.
Few reasons:
  • If you have multiple speakers calibrated as outputs (and calibrated to match), you can apply these folddowns (truly "trims") to any of them.
  • Only 3 (Main, Alt1, Alt2) speaker outputs are accessible from Eucon whereas you can have a lot more folddowns. There is a limit but I don't know what it is but they are all accessible from the Control Monitoring tab (swipe to see more)
  • Following the above Eucon note about Speaker outputs, folddowns show their naming. The speaker outputs only show one of the 3 above. So you can actually see which setup you are recalling with folddowns on the Monitoring tab.
  #223
Old 03-25-2021, 02:37 AM
hitp hitp is offline
Hello Jeff or anyone who can chime in. The speaker delay on the SPQ page is in milliseconds? So for example 6ms would be entered as 6.00, and 12.23ms be 12.23 etc, correct?
Thanks so much.
Dennis Cham
HIT PRODUCTIONS
music | sound design | post
www.hitproductions.net
  #224
Old 03-25-2021, 03:50 AM
ntp-jl's Avatar
ntp-jl ntp-jl is offline
Thanks so much.
Correct .
Jan Lykke
Business Development Manager
DAD - Digital Audio Denmark
  #225
Old 03-25-2021, 06:05 AM
Thank you Jan!
Dennis Cham
HIT PRODUCTIONS
  #226
Old 07-27-2021, 12:40 AM
Mike Thornton's Avatar
Mike Thornton Mike Thornton is offline
I was wondering if there is a video out there about speaker tuning with the MTRX. I'm about to get into that with a 7.1.4 setup and there really isn't much information about saving different tunings and the steps that one might go through in order to do that. If there is some more detailed information than what is in the videos so far I'd love to know. Thank you.
How about 3? Check out my new series How To Set Up The DAD/Avid SPQ Card Using The Free Room EQ Wizard
Hope this helps,
Mike
Mike Thornton MIPS
Chairman Of Production Expert Ltd - home of Pro Tools Expert
  #227
Old 08-08-2021, 12:41 AM
Originally Posted by creativecontrol View Post
So you really need at least a gigabit switch, if not a gigabit router / DHCP server. If a switch, everything will be self-assigned, if a router (best), all devices will be given an IP address. This is also a good idea if you are going to have a combination of Dante and EUCON devices connected as well.
Hi Jeff,
I have been researching a gigabit router but not clear which one to get. A lot of them seem to be primarily for wi-fi, and also I am not sure if they will play nice with Dante. Do you have any recommendations? I want to have a DHCP server on my Dante only 'network Currently it is set with Static IPs using a different ethernet port to my main network with internet access.
Thanks,
Mike
Mike Thornton MIPS
  #228
Old 08-08-2021, 05:54 AM
I think there are several different solutions depending on the use case. For more critical Dante environments, Audinate recommendeds the SG350 series of managed switches which do include integrated DHCP server capabilities. This is probably overkill for the guy with MTRX ST, DVS, and maybe an AVIO. In that case, some of the simple TP-Link routers have worked just fine for me. You can certainly disable the wireless radios if you are not using them.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #229
Old 05-25-2022, 07:38 AM
domilik domilik is offline
Originally Posted by DonRWatters View Post
Yep, that what it was! Thanks so much Jan and Jeff.
Is there a way to lock the HDX card to 48Khz or lock it to the MTRX Studio? If Pro Tools is open, the HDX card follows the session, so that isn't an issue. When I try to open the Advanced window in the Avid ASIO driver the host/parent process is killed, so I haven't been able to set the HDX card sample rate outside of Pro Tools. It seems to default to 44.1 for new processes.
-- Don
Hi there!
Came across the same problem. I do not get the asio driver set to 48khz when I want to use it with third party DAW.
Is there a solution for this?
Thanks, Dominik
PT Ultimate 2023.12
Win10 Pro 64bit, 64GBRAM
MacStudioMax, 64GBRAM, 32GPU, Monterey
MTRX Studio, HDnative, RME UFX, Yamaha 01v96i, S3, S1, PT Dock, Nuendo 12
  #230
Old 04-24-2024, 05:24 AM
thebeatless thebeatless is offline
Reviving this old thread since fan noise doesn't seem to be mentioned anywhere else. I searched everywhere before purchasing and I thought that meant it wouldn't be an issue for me, but it is.
So.... Those of you with an MTRX studio, is yours actually nearly silent? I got one recently and the fan noise has been an issue for me. It's really not very loud, but I can definitely hear it as soon as the music stops or when I walk into the room. In fact, it's much more noticeable than my old omni, and there were a lot of complaints about those.
Avid support says it's normal, so I've listed it for sale since there's a good chance my expectations are just too high. But..... I wanted to see if anyone else has this issue just in case I should try to get this remedied. I really LOVE Dadman, and would love to make it work instead of taking a loss and selling so soon.
MTRX Studio i/o Cheesehead Post - Surround - Video 9 02-21-2021 08:17 AM
FS: MTRX 2x 8 Line Input Pristine Card 1x MTRX SPQ Card antonis Buy & Sell 9 04-11-2020 06:47 AM
Still no specs on MTRX Studio Avid? corp Pro Tools | MTRX & MTRX Studio 51 04-02-2020 05:31 PM
MTRX Studio - No AES?! Ryan Young Pro Tools | MTRX & MTRX Studio 23 02-23-2020 02:13 PM
analog console, next steps for my studio badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-28-2003 08:03 AM
