  #51
Old 10-05-2017, 01:11 AM
EddieJones's Avatar
Default Re: Having issues saving S6 setting to the session
Yes this is fixed with PT 12.8.2 and S6 v3.7. There were 2 parts broken.
  #52
Old 08-09-2018, 07:21 AM
its2loud its2loud is offline
Raising a thread from the dead. Zombie thread?
Are S6 user preferences saved in a Pro Tools session template file?
PT 2018.4
S6 2018.3
  #53
Old 08-09-2018, 07:36 AM
creativecontrol's Avatar
Yes, they should be assuming you enable the Auto-Load option under System preferences to also save prefs.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #54
Old 08-09-2018, 07:58 AM
Yep. All preferences checked.
So here’s another question.
Say you start a session on an S6, save user prefs in session, but then move that session to a room that uses a DCommand and is saved again and moved back to the room with the S6. Are those user prefs still saved in the session?
I’m thinking this is why my user prefs don’t recall when opening a session.
  #55
Old 08-13-2018, 01:03 PM
EddieJones's Avatar
Yes they should be, DCommand doesnt access that space in the session.
  #56
Old 01-16-2019, 01:37 PM
karegranat karegranat is offline
Hi, Eddie!
Waking this thread up form the dead, because I realized today that I still have an issue with settings not being saved with the PT session.
The problem is locked knobs on the master module. I am using the Brainworx SSL channel strip on several channels. On these channels I have locked the master module knobs to display the main DYN-parameters, while I have the EQ expanded on the knob module. Everything works as expected when changing channel attention and going back and forth. But when I reload after saving the session, none of the channels have locked parameter knobs on the parameters I set up.
The blue star appears next to PT on the workstations page,
and I have all the boxes checked on the S6 where you choose what settings to save with the session.
Everything else seems to be saved correctly within the session, as far as I know, and I expected these locked parameter setting to be saved too. But they do not.
Anything I might have overlooked or misunderstood? Any settings that should be ticked/unticked?
Regards,
Javed Kurd,
Oslo, Norway
MacPro late 2013, 32 GB RAM
Sierra 12.12.6
PT Ultimate 2018.10.0
S6 M10 v.18.3.219
  #57
Old 01-16-2019, 01:39 PM
EddieJones's Avatar
I'm pretty sure that has never been saved/implemented. I will check
  #58
Old 01-16-2019, 01:52 PM
These locks were only persistent within the session and get flushed when the session is re-opened.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #59
Old 01-16-2019, 01:54 PM
Jeff
OK, thanks!
At least I know it´s not a malfunction then.
Any hope of implementing this feature sometime soon?
Javed.
  #60
Old 01-17-2019, 09:20 AM
EddieJones's Avatar
I'll add to the list but can't promise any date.
Pan Depth Setting not saving with session ajv205 Pro Tools 10 2 03-18-2015 06:53 PM
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 doubtful guest Pro Tools TDM Systems (Mac) 1 02-06-2013 03:42 AM
Question about setting up a session files, saving/bouncing paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-26-2007 12:55 AM
saving issues mac osx menegaux 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-14-2006 05:33 PM
? saving session as/saving copy of session in surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-05-2002 10:24 AM
