Old 11-15-2019, 10:16 AM
Juan Garcia Juan Garcia is offline
Default Xmon losing connection
Greetings,
I get frequent disconnects from the XMON once or twice a day. Does anyone have ideas on why might this happen? Normally just resetting the app resolves the issue but some other time I have to reboot the whole WSCONTROL and then the XMON app and reconfirm the MIDI port.
The XMON USB cable passes through a 3 meter USB extension and then to the computer. I don't know if this causes an issue with a potential loss of power.
Hope you guys have any input on possible causes and solutions.
Thanks,
J.
Old 11-15-2019, 10:39 AM
creativecontrol's Avatar
Default Re: Xmon losing connection
Greetings,
I would keep an eye out in Audio MIDI Setup (MIDI) on your workstation if you see the icon for the MIDI interface the XMON is using ghosting out and returning. If so, you need to troubleshoot your MIDI interface:
Remove extensions.
Try a different USB port.
Try a powered USB hub.
Swap out the MIDI interface for an alternate.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-15-2019, 02:13 PM
Hi Jeff,
I'll give a try with a different MIDI interface. We use the included USB to MIDI cable that came with the XMON, hence the USB extension.
Thanks for the input. I'll report back if something is still off.
J.
Old 11-15-2019, 04:08 PM
Please do. Also - do a Get Info on your XMON app and let us know what the exact version is please. Thanks.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-29-2019, 06:36 AM
Thanks Jeff.
I've changed to a dedicated MIDI interface and so far no problems whatsoever. Apparently the included USB2MIDI cable was not so trustworthy for us.
I'll report back if any changes occur.
Thanks,
J.
96I/O, XMON, D-command connection sjtae Pro Tools TDM Systems (Win) 12 04-23-2017 10:06 PM
Mic Connection to Xmon or Omni [email protected] Pro Tools HDX & HD Native Systems (Mac) 4 01-23-2015 03:59 PM
D-Command/XMON connection to interface DaleB ICON & C|24 2 04-17-2011 11:20 AM
XMon connection ? PTGuy ICON & C|24 0 11-27-2005 12:44 PM
My 002 keeps losing the connection partytrain 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-02-2004 01:03 AM
