Old 02-16-2019, 08:35 AM
marmouche marmouche is offline
Default Exp Fader and Snapshot issues
I've got this pb when mapping plugins parameters on fader :
I do manage to assign parameters on fader (so as the exp fader zone on the surface) but when I push the attention button on the the track nothing happen on the exp fader zone (parameter don't appear...).
Also: Snapshot name don't appear on the snapshot section on the surface although I've renamed it.
For instance: If I rename the snapshot 1 as "small verb" the snapshot section doesn't update.
Any ideas ?
Thx by advance
Old 02-16-2019, 08:59 AM
creativecontrol's Avatar
Default Re: Exp Fader and Snapshot issues
Greetings,
A few things. If this is an On Attention Expand Fader zone you declared make sure that the zone is not first suspended from the bottom two soft keys located on the Extras page of the right Automation Module.
Also - for the Home page local options you need to declare which function (insert x, sends, Pan, etc) you want to Target On Attention in that zone.
The Auto Snapshots nomenclature issue is known and resolved in the next versions.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-16-2019, 10:02 AM
Ok I"ll check next monday which function is targeted on the expand fader zone and I"ll let you know.
Well noted for the snapshot issue
Thx for your quick answer
best ,
Fader and monitor issues Juan Garcia Avid S4/S6 10 03-26-2018 10:30 AM
Fader issues woodkobi Pro Tools 12 7 06-10-2017 01:11 PM
Fader Issues adam on bass Pro Tools 11 0 12-07-2015 10:35 AM
Please Help! fader issues inky ProControl, Control|24, Command|8 2 01-05-2005 03:59 PM
