S6 Channel Displays
Small function that has possibly gone missing that I use to use all the time. I used to hold shift and then Display 1 or Display 2 on the Monitor module and the channel displays would all toggle through the display options. Having upgraded to latest S6 firmware and Eucon this doesn’t happen anymore. I can still change each channel individually pressing the Attention button and the Select button. Is there a new preference that I’ve missed. Any help grateful let received. Thanks.
Sent from my iPhone using Tapatalk |
Re: S6 Channel Displays
checking on this and will get back to you.. Thanks
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
If you've tweaked individual (custom) meter strips the global functions will ignore those. Try holding Shift + Select on a channel or channels then try your global Shift + Display again.
best, Jeff Quote:
Thanks for that , but didn’t work I’m afraid.
I'm not seeing that behavior here on 23.11.121. What version (PT and S6) are you running? Also - do you have Channel Strip Keys defined to toggle Display Global Meter Layouts and is that functional?
best, Jeff |
Like Jeff is suggesting it does sound like you have the display types set manually, either by individual track or by the new track type (can be different for audio vs VCA etc.)
In the next release we are adding a hold shift and press and hold Display 1 or 2 to clear all individual settings for this. |
Yes there will be a beta coming soon....but please keep beta chats to Center code
Sorry Eddie!
Sorry for the late reply , checked this out I’m afraid it didn’t work. Did a fresh install, all good. Thanks for the help.
Avid C|24 channel name displays | Adam Pistora | ProControl, Control|24, Command|8 | 2 | 10-20-2023 01:09 PM |
Channel Control Displays didn't wake up | SMS_PSH | Avid S1, S3, Dock and Control App | 4 | 11-16-2017 04:12 AM |
Strange CoreAudio issue - right channel information getting into left channel | -JK- | Pro Tools 9 | 5 | 01-10-2011 08:42 AM |
Multi-channel plugin default 'channel view'? | Floydio | Tips & Tricks | 1 | 11-26-2010 10:47 AM |
1 display, 2 displays ..3 displays? what would you | DHG MUSIC | Pro Tools TDM Systems (Mac) | 12 | 10-23-2006 08:59 AM |
