Issue with Knob Expand Zones
Hi all,
While setting up an S6 M40 for an upcoming mix, I'm having trouble with Knob Expand zones. Eucon Workstation and the S6 firmware is on the latest 22.12, and PT is on 23.3. In our current surface configuration, we have one strip containing 2 knob modules on top of a Joystick module. And the knob modules have been set as attention zones. Also, my 1st expand knob function is set to EQ, 2nd is set to Dynamics. The issue arises when I attention a track. Only the 1st expand knob populates (with EQ). There's nothing on the 2nd expand knob module except for the option to bypass the Dynamics plug-in at the far bottom right of the module. So the knob module sees the Dynamics plug-in, but doesn't populate the knobs with parameters. I even tried flipping the EQ and Dynamics. So Dynamics was assigned to the 1st expand knob module, and EQ assigned to the 2nd. But I get the same problem, EQ works but Dynamics doesn't. Am I missing some setting somewhere? Tomorrow I'm going to try importing User and Soft Key preferences from our 2nd Master Module in the room, as this feature was working fine with it last week. But I'd love to hear anyone's suggestions on how to fix this! Thanks in advance! -Preston |
Re: Issue with Knob Expand Zones
Hi Jeff!
Yesterday we were attentioning tracks with Fab Filter's Pro-MB. Today I tested other dynamics plug-ins and everything else worked fine. Pro Compressor, Pro Limiter, Fab Filter's Pro C-2 and Pro L-2, Waves C6, AVA Multiband and McDSP 4030 all worked. But somehow there's still an issue with Pro-MB. Let me know if you have any idea what's causing this. Thanks again! -Preston |
This is actually normal. Especially with AAX tools like Multiband Dynamics, many don't have a concept of a global Threshold, Ratio, Attack, Release... So - I would recommend simply accessing Inserts > Parameters (teal) for any of your Dynamic EQ's or Multiband Compressors, tweak and save optimized custom knob (teal) maps, then use those in your templates.
The DYN (green) function is really setup for the basic compressor limiter parameters and doesn't accommodate more complex processors such as these. best, Jeff |
Expand Zones and Display Modules | laki | Avid S4/S6 | 13 | 10-12-2023 07:36 AM |
Recallable Sends on Faders - Layouts? Custom Maps? Expand Zones? | zeegee | Avid S4/S6 | 3 | 12-10-2021 11:11 PM |
Expand zones and "last selected" setting - inconsistent behaviour | Ivan.S | Avid S4/S6 | 3 | 03-15-2021 09:44 AM |
Dedicated Knob Expansion Zone and WS clicked zones | Ivan.S | Avid S4/S6 | 10 | 09-09-2020 10:07 PM |
S6 exiting expand zones and returning to track mode | PatrickCusack | Avid S4/S6 | 6 | 09-27-2019 02:38 PM |
