Old 04-21-2022, 02:14 PM
basehead617 basehead617 is offline
Default Clip Effects on S4/S6
Just wondering if there's been any thought put into allowing manipulation of the Clip Effects values on a knob module for example?
I know that's really PT-specific so not sure about EUCONization but I can see it being really useful - it could be engaged with Shift-EDIT or something? And the values would auto update as you select each clip.
Also, just so I'm not going insane, there ISN'T a way to do it now right?
Old 04-21-2022, 03:29 PM
creativecontrol's Avatar
Default Re: Clip Effects on S4/S6
100% agree. No current way to do it. Yes, Clip FX uses the Channelstrip algorithm under the hood and we already know how to map that to a knob module. This would be beneficial for all parties.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 04-22-2022, 08:14 AM
EddieJones's Avatar
In the 22.4 release next week you can control Clip Effects from the S6 Master Module with the new Assignable knob feature.
Old 04-22-2022, 08:52 AM
smurfyou smurfyou is offline
That sounds great.
~Will
Old 04-22-2022, 10:58 AM
Thanks Eddie - having watched the tech preview I sort of see what you could do there, however i am really thinking of all of the clip fx parameters available on one bucket’s knob module like an EQ or DYN mode - might need more than one page but..
Hopefully it’s something you’ll consider.
Old 04-23-2022, 12:40 PM
EddieJones's Avatar
We are considering adding them to the Edit knobset, I can't promise a time but its on the list.
Old 05-12-2023, 08:18 PM
zakco zakco is offline
I was excited about clip effects until I discovered that they don't map to the EQ/DYN section of Icon controllers. I thought for sure that this would be available on the S6 or even the dock, but it looks like not which is a huge missed opportunity, workflow wise. I edit dialog and mix TV and I'm automating EQ all day long via muscle memory on the D-Command EQ section. I can imagine giving up that workflow to mouse around a tiny little window. Seems like such a step backwards, no?
Old 05-13-2023, 08:05 AM
Just to be clear, this has nothing to do with automating EQ on D-Command or S6. There are already comprehensive implementations for controlling AAX plug-ins in numerous ways on the surface. This is a new implementation, which indeed should happen as it would be exceptionally useful.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
CLip EFFECTs missing wheelon Pro Tools 2 12-24-2021 05:46 PM
Clip effects as a paid add-on lesbrunn Pro Tools 2020 22 08-04-2020 02:26 PM
Clip Effects SBP Pro Tools 12 1 06-12-2017 04:19 PM
Cannot Edit Clip Effects in PT 12.6 HD conleec Pro Tools 12 81 01-30-2017 07:55 PM
Clip Effects Freezing Carl Lie Pro Tools 12 3 10-05-2016 04:24 AM
