Old 07-13-2016, 02:45 PM
Postman Postman is offline
Default S6 v2.2 with PT12.4.0?
I am so far unable to run a stable PTHD12.5, including 12.5.2. Readme for v2.2 says 12.5.2 is required. Are there known issues with 12.4 (which runs well) or shall I attempt v2.2 upgrade?
system specs in profile
Old 07-13-2016, 03:51 PM
creativecontrol's Avatar
12.5.2 is specifically required for the functionality with the Master Post Module. If you are not using an MPM you can certainly run a previous version.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-13-2016, 04:54 PM
Default Re: S6 v2.2 with PT12.4.0?
Thank you for such a rapid answer, Jeff!
Old 07-13-2016, 05:41 PM
EddieJones's Avatar
Also be aware that there were some pretty big performance issues and bugs fixed for S6 in PT 12.5.2. PT 12.4 will run no worse with v2.2 than v2.1 though.
Old 07-13-2016, 06:22 PM
Default Re: S6 v2.2 with PT12.4.w0?
Eddie, thanks for the info, it is what I hope for.
edit: well, actually, I hope to get to the bottom of my 12.5 problems and be able to access all the S6 features. Until then....
Is there an upgrade from PT12 to PT12 HD? Hot Banana Studio Licensing & Accounts 16 11-21-2015 12:13 PM
PT12 and PT12 HD surround? theom Pro Tools 12 17 10-12-2015 09:27 AM
No PT12 available giacomopasquali Pro Tools 12 9 05-12-2015 04:12 AM
Best OS For PT12 spoons Pro Tools 12 3 04-09-2015 07:57 PM
Pt12 hd Reckless Erik Pro Tools HDX & HD Native Systems (Mac) 4 04-08-2015 04:21 PM
