Old 01-30-2020, 02:31 PM
creativecontrol's Avatar
Default Re: Plugin Windows S6 / Workstation
Greetings,
I would first ask how you have the following preference set...
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-31-2020, 10:14 AM
rcutz rcutz is offline
Hi Jeff, exactly like your picture.
Ricardo Cutz
Re-recording mixer/sound editor supervisor.
Http://106db.com.br
Old 01-31-2020, 10:46 AM
Understood. I am going to make a few assumption now..
If Open Windows on Workstation When Knobs Assigned is Set to the Master Module, then I presume your
Function and Knob Page Selected on Attention Change is set to Pan
and..
You also have Attention Track of Most Recently Selected Surface Function set to On.
Let me know if any of this is incorrect.
thanks,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-31-2020, 11:05 AM
FUNCTION AND KNOB = PAN : CORRECT
ATTENTION = ON: CORRECT
May I deselect "PAN"? There isn't a "none" option?
And the BACKUP FUNCTION"?
Ricardo Cutz
Http://106db.com.br
Old 01-31-2020, 11:13 AM
Default Plugin Windows S6 / Workstation
Thanks for verifying. So essentially what’s happening is when you press a function switch on the Process Module - such as Inserts, you have the preference enabled to Attention that specific track. From the Home > Local Options you have the On Attention set to display Pan on your Master Module. Finally, you have the preference enabled to target the Master Module (which will in your case will be displaying Pan) and the section of the S6 that determines which window if any from the Workstation (Pro Tools) to open.
There are many modifications you can make to change these behaviors. The simplest would likely be to disable the Attention from function option - however I won’t presume to know what you’ve dialed in for your workflows. Hope this helps.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #16
Old 01-31-2020, 12:59 PM
Thanks Jeff. I get a better sense now of what is going on.
I like to have the attention working so I'm trying here with the different options to see what suits best my workflow.
Thanks for all the explanation.
Ricardo Cutz
Http://106db.com.br
  #17
Old 02-19-2020, 04:13 AM
Jeff
Hi Jeff, I have being experimenting with those preferences, selection inserts that I usually don`t use so I don`t get any window just by selecting insert. But every re-start of the S6 (begin of the day) or yesterday after a pro tools crash I got it back to PAN.
Isn't it saved as preference? Is it normal?
best
Ricardo Cutz
Http://106db.com.br
  #18
Old 02-19-2020, 04:16 AM
I would ask if you are inadvertently enabling console preferences to travel with sessions perhaps? If you look at your Auto-Load settings, do you have User Preferences ticked?
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Question regarding open windows on workstation Cryos Avid S1, S3, Dock and Control App 4 10-12-2019 01:57 PM
UVI Workstation not showing up in NEW sessions plugin dropdown DBK AAX Plug-ins 3 03-17-2016 10:55 AM
Help. Plugin windows got BIG markleemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-28-2009 11:47 PM
Plugin windows DannyVanSpreuwel ICON & C|24 0 09-15-2004 05:30 AM
Can Mac 001 plugin's be used with Windows? piccolo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-10-2002 03:38 PM
