Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 12-11-2023, 09:54 AM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
Default Which sfp connections work for DADlink?
Can I use for example a Ubiquiti UniFi patch cable ? (UACC-DAC-SFP10-0.5M)
Or must it be madi sfp ?
Ubiquiti UniFi patch cable is way cheaper option then 2 madi sfp ?
Thanks,
Johnny
PT Ultimate 2024.03.0, Avid S1, Eucon 2023.11
16" MacBookPro (2023) M2 Max 12-core, 64gb Ram, 1Tb SSD, OSX 14.4.1
MTRX v.2.4.2.2 + dante card + madi baseunit + optical SFP 1300nm
MTRX-II v.1.0.5.2 + TB3 + 1x AD mic 8ch + 1x DA 8ch
MOM v.1.0.1.4 by DAD
Genelec 1237A Sam, Avantone active mixcubes
LA2a (1968), 1073 pre/eq, Neve RNHP, Wacom Intuos Pro
Furman P1400 AR E Power conditioner
Live-rack:
1x HD Native TB, 4x 192 I/O (64ch AD)
8x Yamaha HA-8 micpre, Rosendahl mif4,
Genelec 1031A, Presonus Monitor Station
Old 12-11-2023, 11:24 AM
creativecontrol's Avatar
Default Re: Which sfp connections work for DADlink?
Greetings,
I've been using the Avago compatible SFPs from ProLabs: AFBR-5701PZ. From other folks I've talked to, most similar Gigabit+ SFP modules seems to work just fine. I'll defer to others on the Ubiquiti UniFi patch cable question.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-11-2023, 11:38 AM
Interesting question, and for many users a short SFP-SFP copper cable where two boxes are racked together might be more practical than more fragile optical cables.
I think you'll need somebody from DAD to answer that question. Or be adventurous and buy one and see...
You are comparing direct connect copper to optical, so being cheaper is not a surprise, even without the marketing tax for a "MADDI" SFP. You would lose the nice galvanic isolation of optical connections, but that might not matter for you.
MADI, based on old 100Mb FDDI uses the SFP connector. Here you are looking at a SFP+ connector designed for 10Gbit Ethernet (and other networks). But backwards compatibility in SFP/SFP+ means this "should work", but you never know what additional things, including deliberate vendor lock-in tricks might be done.
Old 12-11-2023, 04:14 PM
uptheoctave uptheoctave is offline
Thanks,
Johnny
I've tested 10G copper SFP's just now and it doesn't work, unfortunately.
It needs to be optical, Gigabit or better.
Ubiquiti UF-MM-10G works great here.
They are more expensive than the one Jeff mentioned but I had them to hand.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 12-11-2023, 06:32 PM
BScout BScout is offline
I'd love to know if the DAD branded transceivers are 1Gbit SFP (strangely can't find that info anywhere.) Some pictures show them to be Avago units.
Talking about MOD-SFP-1300-LD (which is the DAD 647-110 unit)
Anyone have the info?
Old 12-11-2023, 08:11 PM
If the module label is not enough...
Anybody with a SFP/SFP+ Ethernet NIC card in their Mac should (might?) be able to plugin one of those modules in and dump some module info, I think it's just in the ifconfig -m -v <interface> output (don't have one here to check).
On Linux it's ethtool -m (what I've actually used anytime to track down what modules are or what they are lying they are).
Old 12-11-2023, 08:34 PM
I have a few on order (hopefully should arrive next week) for a Core256 but don't have the actual modules in-hand yet to look at the label. (and I don't trust the images shown on retailer websites because they have been wrong often.) I have 2 others but they are in use in a different MTRX so can't pull them. And then 2 others are on a MTRX in the UK (far from LA) and we had some trouble there. Can't even remember what is working on that system now (it was one DAD module plus one other but that didn't work. We found that two DAD modules or two of the other module brand worked, but they would not work if they were "mixed" on the same system. Really bizarre and annoying)
I thought for sure that DAD would at least list the specs of their "own" modules somewhere.
Old 12-12-2023, 03:43 AM
None of the previous NTP optical MADI SFPs that were sold are Gigabit including those Avago units you mention - which were the most popular 1300nm optical MADI units.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Connetions connections connections Maxaudio General Discussion 3 09-28-2011 08:50 AM
Can you use the SAS connections,,,,,, pianosound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-14-2011 12:56 AM
5.1 PC Connections Touchwood Studios ProControl, Control|24, Command|8 2 11-18-2008 02:19 AM
888/24 Connections unseen33 Tips & Tricks 4 10-18-2006 06:06 AM
HDD and CD connections Mike Emerson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-06-2002 08:55 PM
