Old 07-14-2020, 11:38 AM
AumStudioBrian's Avatar
AumStudioBrian AumStudioBrian is offline
Default HD Native Connectivity and Cabling
I'm a long-time Pro Tools user, but I'm brand new to Avid HD hardware. I've just recently purchased 2 hardware units: Avid HD 16x16, 8x8, and an HD Native Thunderbolt interface.
My questions are:
1. Do I simply only have to connect each unit individually via DigiLink cables to the HD Native interface?
2. Should one of them be connected via "Primary" port and the other via "expansion" port?
3. Is any further connectivity necessary? IE: Loop sync, etc.
I read through the manual but felt it lacked clarity in this area. Thanks in advance for the help.
Old 07-14-2020, 12:20 PM
creativecontrol's Avatar
Default Re: HD Native Connectivity and Cabling
Greetings.
Depending on the cables you have on hand you can go a few ways:
12' DigiLink cable that comes with HDN - port 1 connect to primary on HD IO A.
If you have a shorty DigiLink - then simply connect expansion from HD IO A to primary of HD IO B.
You can also use 2 12' DigiLink cables to each IO: HDN A - HDIO A primary, HDN B - HDIO B primary. Both scenarios will work.
Lastly, use BNC cables to connect Loop Sync out of HD IO A into Loop Sync in on HD IO B out of HD IO B and into Loop Sync in on HD IO A.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-14-2020, 02:06 PM
Thank you so much for the thorough answer.
Old 07-16-2020, 11:52 PM
mightyduck mightyduck is offline
Originally Posted by creativecontrol View Post
Greetings.
best,
Jeff
Ha, ha. Allow me to inject some possibly unnecessary confusion where there was none before.
Are we absolutely sure that daisy chaining through one interface to another is exactly the same as connecting each interface to its own separate card in the computer. I have a similar situation going on with some older 192 I/Os, and I read the ___ing manual and [since I could not find my second long digicable] I daisy chained them because the manual says that you gain nothing by connecting them separately.
HOWEVER, in my typical paranoid manner, I am wondering if it is really true, or would I gain one one millionth of a measurement unit advantage by connecting them separately with cables of the exact same length.
Please understand the scenario running in my head. You see, as I imagine it, I do a whole bunch of super important work [it could happen, just ask Judi Tenuto] on my rig while it is connected in the daisy chain manner. Then someone posts a long detailed thread explaining why doing that is just not quite right, causing me to have to either redo all the work [without telling anyone] or suffer the humiliation and shame of knowing that "I did it wrong". There is a third scenario where I just leave the result alone after doing it wrong, but I tell everybody that I did it the right way. But then somebody finds out and I am forced to suffer the humiliation anyway.
So...........is it really exactly the same?
As you can see, I really need help with this. :)
Best,
mightyduck
MD
Old 07-17-2020, 12:07 AM
I have no idea what you are worried about... what exactly is not working right?
The Digilink aka TDM2 bus connection here is about as dumb as it is possible to design (it is ancient technology). You've got so many slots for interfaces on all those TDM2 Busses, and it makes no difference where interfaces are connected or in what chain order etc.
There is lots of stuff to worry about, lots of mistakes you might setting other stuff up right, I'd worry about those other ones.
Old 07-24-2020, 06:31 AM
I refuse to worry about the other ones. I insist on obsessing on this one. So there. I demand an official AVID announcement on this issue since it is the issue that I have chosen to obsess about. : )
mightyduck
MD
New HD user, a little help with cabling, etc 68topls Pro Tools TDM Systems (Mac) 0 01-18-2010 07:55 PM
Cabling Help 6string Pro Tools TDM Systems (Mac) 2 01-06-2010 07:51 PM
Cabling C24 aztlan2010 ICON & C|24 6 05-21-2009 04:47 PM
SPDIF cabling vs. Hi-Qual RCA cabling - difference? SixChurchStreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-12-2007 04:16 PM
Where do you order your mic cabling from? pedrohead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 05-04-2004 04:21 PM
