Old 02-01-2008, 12:15 PM
uno1234 uno1234 is offline
Default Is there a way to link track select and track focus?
Maybe I'm missing something obvious. I like track follows edit selection, and I feel it would be more powerful if I could link track selection with track focus.
Old 02-06-2008, 12:35 PM
Top Jimmy's Avatar
Default Re: Is there a way to link track select and track focus?
Select/Focus Mode Switch and Indicators
The Select/Focus Mode switch toggles the function of channel Select switches between Select and Focus mode. In Select mode, channel Select switches are used to select channels in Pro Tools. In Focus mode, channel Select switches are used to focus a channel’s controls on the Focus Channel Strip on the Main Unit.
The LEDs on either side of this switch indicate the current mode.
As snipped from the D-Control guide
James Cadwallader
Old 02-06-2008, 01:21 PM
Drew Mazurek's Avatar
Uh, yeah, and he wants the option for them to be linked so that selection and focus will happen simultaneously.
www.drewmazurek.com
Old 02-06-2008, 06:50 PM
Brandonx1 Brandonx1 is offline
Great Idea!!! DIGI are you listening???
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 02-06-2008, 08:03 PM
I love it when people dont read the question and assume I haven't read the manual. Nice.
Old 02-07-2008, 03:07 AM
Mikey MTC Mikey MTC is offline
I would LOVE this to be added as a pref. For 95% of my workflow it would be the best of both worlds.
Old 02-07-2008, 05:22 AM
Even better would be Touch Focus, like most digital consoles.
www.drewmazurek.com
Old 02-10-2008, 09:29 AM
creativecontrol's Avatar
If this preference existed what (focus) behavior would you expect if you selected a range of channels either contiguous or not? Just curious...
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-10-2008, 01:48 PM
Good question! Perhaps just the first one in the selection gets (or remains) focused.
Old 02-10-2008, 04:05 PM
Maybe the last selection button hit stays in focus. So, if I select 1-8 channels, then hit channel 2 select button. channel 2 goes into focus but the range stays selected. If you want to deselect the range, just command + select the range and that channel is removed from the selected range or hit the select button outside of the range. How does that sound?
Best,
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Stop fader banks from following track focus? trustyjim ProControl, Control|24, Command|8 14 02-02-2013 05:13 PM
Link sélect track ByPass ICON & C|24 2 06-13-2011 11:36 AM
track show and hide with link track and edit selection ???? x9blade Pro Tools TDM Systems (Win) 4 10-11-2008 10:08 PM
"select next/previous track" "rec enable track" key command? maufau Pro Tools TDM Systems (Mac) 6 04-22-2008 05:08 PM
PT 6.9 track select bug trakbytes Pro Tools TDM Systems (Mac) 3 04-20-2005 03:20 PM
