Old 08-21-2018, 12:59 PM
creativecontrol's Avatar
Default Re: MTRX and S6
We need more data.
Are there sources on the top of the monitor window on the Master Module?
Are there speakers on the bottom of the monitor window?
Do you see fold-downs at the bottom?
Are the A-D monitors - left column on monitor page accessible? Is there anything on the monitor window? A screen shot or cell pic might help.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-21-2018, 01:19 PM
quadraphonics quadraphonics is offline
Again, thank you Jeff.
There are no sources on the monitor window on the master module. I only have 'Intercancel' and 'all'
There are no speakers on the bottom of the monitor window.
There are no folddowns on the automation module softkey window. In fairness, I haven't set any up because I am handling that outside of the MTRX.
Originally Posted by creativecontrol View Post
We need more data.
Jeff
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 08-21-2018, 01:22 PM
Those Soft Keys indicate that DADman is focused / the application in the foreground. Is Pro Tools launched and opened with a session up?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-21-2018, 01:32 PM
Yes, Pro tools is launched and up. I focused the DADMan software in order to take the picture.
Randall
Jeff
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 08-21-2018, 01:34 PM
Please take a picture of the Monitoring Soft Keys on the S6 (MAM) when Pro Tools is focused / in the foreground. You can get there with either Shift + . or from the Control Room Soft Keys accessible from the Extras page on the right Automation Module.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #16
Old 08-21-2018, 02:32 PM
Here you go.
Jeff
Randall Smith
Audio Editor/Mixer
Denver, CO
  #17
Old 08-21-2018, 02:46 PM
Did you customize all of your Soft Keys? These don't appear to reflect the factory set.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #18
Old 08-21-2018, 02:50 PM
I have custom softkeys, but not on either of these two pages.
Randall
Jeff
Randall Smith
Audio Editor/Mixer
Denver, CO
  #19
Old 08-21-2018, 06:12 PM
We need more data to troubleshoot this properly, including history.
Is this a new issue? What has changed in your configuration since you were operational previously?
This really feels like a binding issue. I would try most of the following:
Quit WSControl. Quit DADman and Pro Tools. Reboot your computer. Launch DADman and Pro Tools. Application switch between Pro Tools and DADman to see if you have proper binding. Verify your monitor profile. Load a few different monitor profiles. You should see sources, speakers, monitors and folds appear on the Master Module Monitoring page and on the Soft Keys (MAM). Ensure that you aren't simply missing your sources on the input which can be populated from the source selection list:
http://avid.force.com/pkb/articles/h...s-MTRX-with-S6
Verify the binding. Un-bind - by pressing the Setup button on the top of the physical monitor controls on the Master Module. Press again to re-bind.
Note that monitoring controls which appear as faders (when DADman is in focus) will be there regardless of the state of binding.
Is the S6 and the MTRX on the same subnet? Are they being supplied IP addresses by an external router? Let us know what you find.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Pro Tools MTRX LukeHoward Pro Tools | MTRX & MTRX Studio 170 12-29-2017 02:47 AM
MTRX Box JSR Avid S4/S6 4 11-01-2017 12:46 PM
MTRX antonis Post - Surround - Video 2 10-26-2016 12:31 AM
Avid MTRX Rpro System 5 2 10-12-2016 07:40 AM
