Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #31
Old 06-15-2023, 11:37 AM
creativecontrol's Avatar
Default Re: MTRX Studio with HD I/O
The mini DigiLink connector attached to a DigiLink port is capable of passing 32 channels at all sample rates.
For HD Omni, make sure you connect it as the primary interface attached to the 1st port of your engine card. You can then attach a single HD IO to the expansion port of the HD Omni, and up to 2 additional HD IO's to the 2nd port of your engine card.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #32
Old 06-18-2023, 08:41 PM
patmaki patmaki is offline
Thanks for confirming!
  #33
Old 07-04-2023, 02:16 AM
Allar Allar is offline
Originally Posted by creativecontrol View Post
Greetings,
Yes, the recommended way to deploy would be to fully hook up 64 channels (2x 32 channels of DigiLink) from MTRX Studio for example to HDX Card 1, then to hook the 2 HD IO units to HDX Card 2.
best,
Jeff
How would be the recommended way to connect cables for sync? Before we got MTRX studio, the two HD I/O-s were synced via loopback but how should the MTRX studio be added to the loop? Do I need to put the three units into the loop or does the MTRX provide clock via digilink?
Thanks!
  #34
Old 07-04-2023, 05:36 AM
You can simply set the MTRX Studio to Loop Sync, after expanding your existing HD IO Loop to include MTRX Studio. In DADman to to Conf > Sync > Sync source > Loop Sync.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #35
Old 07-04-2023, 07:22 AM
Thanks!
Can the master also be the MTRX Studio or it does not matter until the syncing is done properly? Does the MTRX Studio and HD I/O have the same quality clock?
  #36
Old 07-04-2023, 12:18 PM
Another valid option would be to set the Sync source in DADman to Internal and use the MTRX Studio as the primary device to send Word Clock to your HD IO interfaces. I would encourage you to compare the two options, however I don't believe you will be able to perceive a difference in quality.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #37
Old 07-04-2023, 01:19 PM
Hi Jeff and thank you again for the reply!
Why I asked my previous question is the fact that I get crackling and heavily distorted sound when I try to record via HD I/O. I thought that it might be the clock issue but tried diffrent clock sync setups. Sync loop, WC but no luck.
I think it has something to do with HDX cards or the order of devices. I tried diffrent connection setups.
I currently have the following setup:
MTRX Studio port 1 is connected to the first HDX port 1. Second HDX is connected to the HD I/O (nr1) primary port and HD I/O (nr2) is connected to the expansion port of HD I/O nr1.
I also tried this version: Yes, the recommended way to deploy would be to fully hook up 64 channels (2x 32 channels of DigiLink) from MTRX Studio for example to HDX Card 1, then to hook the 2 HD IO units to HDX Card 2.
Im using Sonnet Echo TB3 chassis.
Should I try with only one HDX card for a start?
all the best!
  #38
Old 07-04-2023, 04:58 PM
Please send us some more details on your recording setup so we can help troubleshoot:
Computer / Specs
macOS Version
Pro Tools version
Which exact TB3 Chassis
Have you run DigiTest on the HDX cards or has everything been tested and QC'd prior to adding the MTRX Studio?
You can also PM me directly if that's more expedient.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
First steps with MTRX Studio SMM Pro Tools | MTRX & MTRX Studio 236 Yesterday 03:49 AM
MTRX Studio i/o Cheesehead Post - Surround - Video 9 02-21-2021 08:17 AM
MTRX Studio and MOM Awesomeness DonRWatters Pro Tools HDX & HD Native Systems (Win) 5 12-07-2020 05:23 AM
How to tune SPQ card in MTRX Studio nedd Post - Surround - Video 13 07-31-2020 09:55 AM
MTRX Studio - No AES?! Ryan Young Pro Tools | MTRX & MTRX Studio 23 02-23-2020 02:13 PM
