Old 03-18-2021, 11:23 AM
geofmitchell geofmitchell is offline
Default toggle between object and bed on S6
Other than mousing or the soft key, is there a quick way directly on the channel strip to toggle between object and bed?
Tks
Old 03-18-2021, 12:52 PM
creativecontrol's Avatar
Default Re: toggle between object and bed on S6
Yes, you can use the Bus function from the function scroller on the Master Module or the encoders on a channel strip to access Object / Bus toggling:
Around 01:25:
Object Bus Toggle
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-18-2021, 07:46 PM
Perfect! - thanks for rapid response!
Old 03-23-2023, 06:25 AM
Gregor B. Gregor B. is offline
Dear Jeff,
Revisiting this:
Now that we can program channel strip soft keys, it would IMMENSELY helpful to add 'object toggle' as one of the possible channels strip key commands.
When mixing in atmos, I find myself kicking channels into objects at a very fast pace from the console and it would be wonderful to be able to do that straight from the surface (channel soft keys) as it's so much more handy and also makes it more visible, like if one was to program it to the 'rec' or 'input' fields. Going to 'bus' for every channel one by one and toggling there takes more time and makes it invisible once you page back to the EQ (I only ever visit the 'bus' page when toggling objects).
Thanks & Best!
Gregor
Old 03-23-2023, 02:39 PM
basehead617 basehead617 is offline
+1 !
Similar in usefulness to DSP Mode, which is an option.
Old 03-24-2023, 06:38 AM
That is a good idea indeed. I will make sure product management is aware of the request.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Toggle between edit- and object selection - key command? tubeass macOS 3 12-12-2016 05:47 AM
"Fic Object Nil" shoo Pro Tools TDM Systems (Mac) 2 11-05-2003 06:00 AM
Need troubleshooting help: "Fic Object Nil" Pootkao 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-20-2003 03:02 PM
Money IS an object... Rock_Artist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-10-2002 09:08 AM
Object selection bug doug sjostrom General Discussion 1 08-16-2000 08:29 AM
