Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #161
Old 08-06-2020, 09:11 PM
Goombot Goombot is offline
Default Re: First steps with MTRX Studio
Hey Jeff,
So after using the MTRX for probably over a month now I just wanted to point out one thing. I usually launch the DADMAn software first then launch EuControl and ProTools. I always see level in DADMan but as my session goes after a while I may flip back to DADMan and I'll see no level on the meters. it's like the program disconnects itself. Everything is the same, the MTRX is locked and ProTools is playing back fine but I loose metering. Is this happening to everyone that has this?
  #162
Old 08-06-2020, 11:59 PM
uptheoctave uptheoctave is offline
Originally Posted by Goombot View Post
Hey Jeff,
I would have Eucontrol start up before Dadman.
What switch do you have?
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
  #163
Old 08-07-2020, 06:44 AM
No switch. Mac trash can going straight into MTRX. But, I am about to get a New MAC Pro with a gigabit switch. Is there a preferred one for Dante because I’m also going to hook up a DAC to it it.
  #164
Old 08-07-2020, 09:16 AM
Originally Posted by creativecontrol View Post
MTRX Studio has Dante and ADAT Optical for Digital IO - in addition to DigiLink obviously. If you need AES you could add an Audinate AVIO for example:
AES3 <-> Dante:
https://www.audinate.com/products/de...ante-avio#aes3
Jeff
Hey Jeff,
So if I wanted to go Dante into a DAC what would you recommend being the best setup for this? Can I directly out of the MTRX secondary Dante port or would I have to go out of a gigabit switch and if so how am I getting the MTRX signal to the DAC? Thanks. chris
  #165
Old 08-07-2020, 09:19 AM
creativecontrol's Avatar
Default First steps with MTRX Studio
So you really need at least a gigabit switch, if not a gigabit router / DHCP server. It’s not really a good idea to cascade assign the network with the second port on the MTRX Studio. If a switch, everything will be self assigned, if a router (best), all devices will be given an IP address. This is also a good idea if you are going to have a combination of Dante and EUCON devices connected as well.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #166
Old 08-07-2020, 09:22 AM
Ok. Are there any routers that Avid recommends that will work best? Thanks.
  #167
Old 08-07-2020, 10:50 AM
You want either an unmanaged switch that does not support EEE or a managed switch that allows you to set up QoS and defeat EEE.
James Richmond
Affiliate Links:
  #168
Old 08-08-2020, 05:06 PM
Thanks Jeff. That was extremely helpful for my order.
  #169
Old 08-08-2020, 05:12 PM
Jeff, I know this is possible but I'm still having a hard time with the signal routing in DAMan. I got a SPL DAC that I'm using with a pair of HEDD headphones. Ideally what I want is my fold down and my Mac output to go to the DAC. Can I do that? Right now I'm just patching the Line Outputs 9 and 10 straight into the DAC. I will change that in the future using my Audinate Dante to AES but I need that switcher first so for now I'm just using the Line Outputs analog.
  #170
Old 08-08-2020, 05:54 PM
Right-Click in blank area of Monitor Profile. Add Monitor. Rename it SPL HP or whatever. Expand the disclosure triangle. Right click on sources. Add existing. Bring in your PT and DVS sources this way. Outputs. Right-click to add a new output set. Rename it SPL, it should default to stereo. In the right side of the interface assign it to the IO it’s coming from. Right click on FoldDown and add existing fold presets you’ve already been using also to this monitor.
That’s pretty much it.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
MTRX Studio i/o Cheesehead Post - Surround - Video 9 02-21-2021 08:17 AM
FS: MTRX 2x 8 Line Input Pristine Card 1x MTRX SPQ Card antonis Buy & Sell 9 04-11-2020 06:47 AM
Still no specs on MTRX Studio Avid? corp Pro Tools | MTRX & MTRX Studio 51 04-02-2020 05:31 PM
MTRX Studio - No AES?! Ryan Young Pro Tools | MTRX & MTRX Studio 23 02-23-2020 02:13 PM
analog console, next steps for my studio badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-28-2003 08:03 AM
