Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 03-15-2021, 08:32 AM
mman00 mman00 is offline
Default New MTRX Studio Does Not Connect to Network
We received delivery of a new MTRX Studio, and we are having trouble connecting it to the network.
We are using a Cat6 Gigabit cable to a gigabit switch which does not light up once the connection is made. DADman does not see it either.
Also, tried connecting directly to the Mac ethernet port. No luck.
Are we missing something stupid? Do we need to go through the Reconfig process?
Thanks for your help.
2018 Mac Mini
10.14.6
DADman 5.4.4.2
PT Ultimate 20.12.0.190
Old 03-15-2021, 09:53 AM
creativecontrol's Avatar
Default Re: New MTRX Studio Does Not Connect to Network
Greetings,
Does your device power up and show illuminated controls? Have you launched DADman and gone into Settings > Device List?
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-15-2021, 10:07 AM
Hi Jeff.
Thanks for helping out. Yes, it powers up and the front panel lights up.
But, it does not connect to the network. The network switch does not light up, and I cannot see it in DADman Device List, even after refresh.
Let me know if there's anything I can try. Thanks
Old 03-15-2021, 11:34 AM
Just to the right of the IEC cable, there is a recessed reset switch. Try holding that down for several seconds then let it go. You should hear relays click and the unit power cycle itself. Open DADman and go to Settings > Device List and see if you can tick Connect to grab the detected device. Let us know.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-15-2021, 11:46 AM
Hi Jeff.
As you suggested, I held the Reconfig Button down until it flashed green 3 times, and the unit went through a power cycle. But still no network. Nothing in the Device List in DADman and no network indicators lights on the MTRX ethernet ports or the network switch.
Anything else we can try? Thanks
Old 03-15-2021, 12:03 PM
Please start a new case if you don't already have one and I will have someone reach out. Send me the case# please.
https://avid.secure.force.com/pkb/ar...-Case-Creation
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-15-2021, 12:12 PM
Hi Jeff.
I did start a case. Case number is 04136745
If there's anything you can do to speed this up, that would be much appreciated.
Thank you.
Old 03-15-2021, 12:45 PM
Originally Posted by mman00 View Post
...We are using a Cat6 Gigabit cable to a gigabit switch which does not light up once the connection is made. DADman does not see it either. ..
Stupid thing to ask, but have you tried power-cycling the switch with everything connected and powered up? I run a setup that's similar and anytime I add in any Dante peripherals, the new network connections don't show any activity until I power-cycle the switch itself.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 03-15-2021, 12:59 PM
Thanks, but that did not work.
There are no lights on MTRX rear panel network ports that indicate a signal is being sent from the unit. I'm beginning to think the network card in the MTRX is defective.
Old 03-15-2021, 01:23 PM
ntp-jl's Avatar
ntp-jl ntp-jl is offline
Just a stupid question, have you tried another network cable? And have you tried both network ports on the MTRX Studio?
Jan Lykke
Business Development Manager
DAD - Digital Audio Denmark
MTRX Studio Mac Pro Not in Synch on Dante Network Goombot Pro Tools | MTRX & MTRX Studio 16 08-07-2022 09:02 PM
MTRX Studio DADman-Network Connection Error pablovius Pro Tools | MTRX & MTRX Studio 39 07-03-2021 10:50 PM
MTRX Studio - No AES?! Ryan Young Pro Tools | MTRX & MTRX Studio 23 02-23-2020 02:13 PM
S6 Talkback>MTRX>Source connect DHS Avid S4/S6 1 11-25-2019 04:08 PM
MTRX and S6 Network Connections laki Avid S4/S6 4 10-31-2017 06:37 PM
