Old 12-06-2001, 05:37 AM
chilli chilli is offline
Default vst usb floppy
any one know of any issues with the new g4 867 macs and the vst floppy drives ?..have followed previous instructions carefully and cannot get one to authorise any plug ins with this mac..have downloaded the appropriate vst floppy support drivers as well as the usb floppy enabler driver (2.1.6 and 2.1 respectively)..also when i look here http://www.paceap.com/usbdrive.html
it doesent actually list the vst usb floppy as supported..i bought that drive on the strength of previous posting here that said it worked....who has had joy with this drive for authorising floppy disks and can they perhaps tell me where im going wrong ?
Thanks
Old 12-06-2001, 08:57 AM
DigiTechSupt's Avatar
Default Re: vst usb floppy
-The VST FDUSB-M drive is the only VST drive that is compatible with PACE copy protection. Are you using this particular drive?
-What happens when you insert a diskette and run the DeAuthorizer? Does it mount?
-Upgrade to USB Floppy Enabler v2.1.2, available here.
Brent
Avid Audio Tech Support
Support FAQ
Old 12-06-2001, 10:26 AM
it is definately the FDUSB-M drive..and i have installed the two files including the 2.1.2 floppy enabler that have been mentioned in numerous mails in the past,,it recognises the floppy but wont authorise..will keep trying
floppy authorizations on G4? didger Pro Tools TDM Systems (Mac) 9 07-20-2003 12:37 AM
do I need a floppy drive to run pt 5.0.1? pleasedonthitme Pro Tools TDM Systems (Mac) 1 06-21-2002 08:36 AM
Floppy or iLok? Don Z 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-20-2002 12:10 AM
will the VST USB floppy works ??? dw Pro Tools TDM Systems (Mac) 11 05-19-2001 07:07 PM
USB FLOPPY SPIDEE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-01-1999 07:32 AM
