Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 09-19-2021, 04:38 AM
Southsidemusic's Avatar
Default Panic about new Carbon purchase connections
Ok so we bought a carbon to try out properly. As many know we have a bog full studio but the tech stuff is something I suck at.
So it says that Carbon runs on Ethernet cable (included?) or thunderbolt ethernet to Thunderbolt. So it also says some ethernet to tbolt doesn’t work with AVB so what do we actually need as we will run the Carbon on a 12 core trashcan and Thats Thunderbolt 2 as we have our 7.1 macs filmed with Apollo X series so this carbon has to work with a trashcan. I still use mojave but thats not gonna work as I read so about the connections, can or should we use the ethernet cable included or buy a adapter, if so do we need a tb 3 and then a tb2 too as the Mac is TB2?
Did we buy the carbon before thinking about this as it might not work with a Trashcan?
Please please advice you guys who run Apple and know what is best, ethernet from Carbon into ethernet port on trashcan or adapter and what do we need? One or two for tb3 or tb2 depending on what Carbon needs using the ethernet cable as there isn’t a Tbolt port on the carbon which we found out after unpacking so WTF is there no TB port ??? Feels very old!
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-19-2021, 04:46 AM
Sardi Sardi is offline
There’s no TB port because it doesn’t connect via TB. It’s using AVB which connects via Ethernet.
Go directly via Ethernet to the Carbon. The Trashcan has 2 x Ethernet connections, so you’re fortunate in that you don’t need an adaptor if you need Ethernet for other usage.
Also, you’ll need to upgrade that MP 6,1 to Catalina and run minimum PT 2020.11.
Old 09-19-2021, 05:01 AM
Default Re: Panic about new Carbon purchase connections
Wow Thank you brother! So we dont need to run the carbon with Thunderbolt then and use it like you described? That sounds soo much easier
So as we never used catalina does anyone know where to download the 10.15.0 as we cant go direct from mojave to atalina 10.15.7 combo as it says we need 10.15.0 first. Anyone have any idea where to downmoad the first Cat so we can then run the 10.15.7 combo or single version. Still dont know what combo means as i thought we could run that right over mojave but that doesn’t work
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 09-19-2021, 05:20 AM
its2loud its2loud is offline
This should do the trick. Follow the link using safari only then scroll down the page.
https://support.apple.com/en-us/HT211683
Old 09-19-2021, 05:57 AM
its2loud’s link will get you the Catalina installer. It will be the latest release, so no need to grab any updates after that. There may be some security patches, but just run software update once installed and it will update those.
FYI - Combo updaters contain all the point updates. So if you had 10.15.0 installed, the 10.15.7 combo update contains all the incremental changes from .0 to .7. A regular update only contains the changes from the prior release. Eg: .6 to .7. That’s why combo updates are much bigger in size compared to regular updates.
Old 09-19-2021, 06:42 AM
You guys are incredible
Huge Big Warm Thanks from a Cold rainy sweden. Gonna try this in a few minutes! Best / Christopher
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 09-19-2021, 03:19 PM
jeffro's Avatar
jeffro jeffro is offline
I'm running mine on a 2019 iMac's built-in Ethernet, but have also run it with the recommended adapters.
The Pro Tools | Carbon Support and Compatibility KB (linked from the Start Here sticky at the top of this subforum) has a section about Network Requirements & AVB Adapters that covers this. Hope that helps!
• linkedin •
Old 09-19-2021, 03:21 PM
You are the Best Jeffro and all you kind helpful members
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 09-24-2021, 06:02 PM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
Works great on a Trashcan here.
Old 09-25-2021, 01:22 AM
Yes it works perfect here too thanks to all your help
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Carbon pre-purchase questions Bennett Paster Pro Tools | Carbon 8 08-13-2021 10:54 AM
Thank you for your recent purchase? What purchase? lol risey Licensing & Accounts 12 05-12-2018 02:44 PM
Connetions connections connections Maxaudio General Discussion 3 09-28-2011 08:50 AM
Mbox 2 Mini causes Kernel Panic after 8 months of no issues. Panic Report Included... oneakmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-09-2010 08:52 AM
