Old 10-11-2009, 06:59 PM
audiogeekzine audiogeekzine is offline
Default Advice needed on HD3 rig setup
My new job has me setting up an HD system for the new studio. I've got things working but I don't think I've got the most efficient/completely correct configuration. It was more complicated than I expected.
G5 (single core, might be swapped with another one)
1 PCI core card
1 PCI Process card
1 PCI Accel card
PT HD 7.3.1 (for now)
192 #1:
8 analog inputs and outputs
various digital inputs and outputs
192 #2:
8 analog inputs
16 analog outputs
Preamps are
2x API 3124+ (4 channel each)
2 channels of TL Audio something old
more coming
24 channels of API summing (8200x2 + 8200A)
I have just 16 connected right now
I don't know if these even make sense to use.
Presonus Central station
Joe Meek compressor
Manley Massive Passive
Live room snake goes into the 10 preamps. Outs of the preamps go into the 192 analog input -4dB jacks.
Interface cable connections:
192#1, primary connection to Core card.
192#2, primary connection to accell card.
I have the effects rack to connect (Lexicon 480L and others) and I have to get the output of the summing mixers back into Pro Tools for mixdown. And headphone mixes.
Any help with this would be greatly appreciated.
Also, with the Voice assignment, DSP allocation business, what's the best way to go? I just don't understand the options at all. why would you want to reduce the # of voices. Why use more DSP for the same # of voices?
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 10-11-2009, 07:51 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Re: Advice needed on HD3 rig setup
Observe the slot order on the cards, should be Core, Accel card, Process card.
If you have a lot of outboard gear, a patchbay's not a bad idea, though more time consuming to wire/plan.
Keep in mind that regardless of how many physical I/O a 192 has with add on cards, it can only access a total of 24 at a time (i.e. 16 ins and 8 outs or 8 ins and 16 outs).
Voice count is how many simultaneous tracks can play at a time(you can have more tracks than voices if they aren't all playing at the same time). Using RTAS plugins will reduce this number. Your settings for this will likely vary depending on your session. Best bet is to start a session with as many voices as possible, then free up the DSP later if you need it.
Old 10-11-2009, 08:05 PM
we were hoping to have the outboard gear as hardware inserts but I think we need more cables first.
There is a patchbay available but we're avoiding it for now.
I wasn't aware of that I/O limitation
@theaudiogeek
Old 10-11-2009, 08:19 PM
Tweakhead Tweakhead is offline
Not true. If the 192 has an analog output expander it can run 8 analog inputs, plus 8 digital inputs, plus 16 analog outputs. That's 16 ins and 16 outs.
Old 10-12-2009, 06:43 AM
any ideas for improving the configuration?
@theaudiogeek
Old 10-12-2009, 07:55 AM
formfunction formfunction is offline
but the 8 digital ins limits you to 48khz. (ADAT) ff
Old 10-12-2009, 08:45 AM
how would you manage cue mixes in this setup?
@theaudiogeek
Old 10-12-2009, 09:37 AM
crizdee's Avatar
crizdee crizdee is offline
1. Patchbay
2. Pro Tools installation engineer
Producer, Engineer,
www.ukmastering.com
Old 10-12-2009, 09:41 AM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
Not if you use AES.
Derek Jones
Sound Engineer / Producer / Composer
Derek Jones Linkedin
Megatrax Recording Studios
Megatrax Studios Yelp Page
A-list Music Artist Page
Old 10-12-2009, 09:43 AM
O.G. Killa's Avatar
using less voices frees up DSP for plugins. Using more DSP for the same # of voices spreads the mixer across multiple DSP. Sometimes in really densely edited sessions, spreading the mixer across more DSP helps keep the session running smoothly.
For me personally, I usually try to keep the voices set to 2 DSPs 96 tracks, unless I'm doing a big session.
Derek Jones
Advice needed to upgrade older setup. needtopractice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-21-2011 06:05 PM
HD setup help needed! megahurt Pro Tools TDM Systems (Mac) 7 05-06-2010 02:26 PM
Advice needed for a new music setup with HD3 lionel payet Pro Tools TDM Systems (Mac) 4 05-23-2005 04:13 AM
Studio Setup Advice Needed cc1 Pro Tools TDM Systems (Mac) 3 11-04-2004 07:37 PM
Help...Advice needed re ATTO Setup tomhartman Pro Tools TDM Systems (Mac) 2 04-22-2001 12:08 AM
