Old 11-27-2005, 10:17 PM
woodbeatz woodbeatz is offline
Default Using pro tools as a slave to my Korg Triton
hello, what i am trying to do is use pro tools as a slave to the triton. i want to sequence normally on my triton but be able to edit all of what i sequence in protools. how can i do this? i can do individual tracks but how can pro tools follow what i do on the korg?
thanks
Old 11-27-2005, 11:17 PM
Phil Jeffers Phil Jeffers is offline
Default Re: Using pro tools as a slave to my Korg Triton
You should be able to slave PT's via MMC. This may be limited for your use, but you should be able to trigger PT's if you enable MMC & put PT's online. An interface such as a MOTU MTP or DTP may be useful also. You'll need to connect MIDI & select MMC via peripherals.
Is it possible to slave the 002 to a Korg Triton Extreme? Pongamoosic Tips & Tricks 6 03-22-2012 02:36 PM
korg d1600 being slave a slave to pro tools sbag MIDI 0 04-12-2007 06:50 AM
Slave Protools to incoming MTC from a korg Triton Solouno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-16-2006 09:41 PM
Pro-tools = Master...............Triton = Slave Brick Adams Tips & Tricks 1 03-29-2005 08:12 PM
pro-tools = master...............triton = slave Brick Adams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-26-2005 03:06 PM
