Old 04-20-2001, 09:46 PM
tomhartman tomhartman is offline
Default Help...Advice needed re ATTO Setup
I'm about to take delivery on a Mix Plus system. Currently, I have an 001 and am using an Adaptec 2906 card in order to use my SCSI CD burner.
When the system comes, and I install the ATTO Dual channel card, and the two Digi Cards in the Mix Plus system, that will fill up the slots on my G4 400. Does this mean I'm out of luck for using my CD burner, or can the burner be simply attached to one of the two 18 gig drives I'll have hanging off the ATTO card?
Thanks
Old 04-21-2001, 06:19 AM
BDWillis BDWillis is offline
Default Re: Help...Advice needed re ATTO Setup
Hey Tom - First a question… is the CD burner a Narrow device? (if unsure, get info in FWB… Narrow is 8 bits, Wide is 16 bits).
If CD burner is indeed Narrow: both 18 Gig drives on ATTO channel 1; CD burner on ATTO channel 2 with step-down terminator from Wide to Narrow bus BEFORE connecting to the burner (gives 18 extra pins proper termination), then Active terminator on the burner's other SCSI connector. My CD burner & DDS3 drive weren't happy with passive termination.
Warmest Regards,
Brian
Old 04-22-2001, 12:08 AM
snoopy snoopy is offline
Or if you do put the burner on a chain with a hard drive, make sure it is last in the chain.
Colin Miller
Teaboy Audio Recall Sheets
http://teaboyaudio.com
Advice needed to upgrade older setup. needtopractice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-21-2011 06:05 PM
Advice needed on HD3 rig setup audiogeekzine Pro Tools TDM Systems (Mac) 25 10-13-2009 08:28 PM
Advice needed for a new music setup with HD3 lionel payet Pro Tools TDM Systems (Mac) 4 05-23-2005 04:13 AM
Studio Setup Advice Needed cc1 Pro Tools TDM Systems (Mac) 3 11-04-2004 07:37 PM
Atto speed with PTHD / Drive space needed etc.. Kurtstudio Pro Tools TDM Systems (Mac) 1 01-18-2002 05:13 PM
